Sharing memory
AV_Tech
in Propeller 1
Hello all.
Someone now I am working on a system with an Propeller and an i4004 processor. I do this in Spin on this moment. But a part of the system I want to rewrite in Pasm for the speed.
http://forums.parallax.com/discussion/164728/i4004-robot
To develop this I take little step's. 1 Step is to understand how to use the sharing of a lot off memory between Spin and Pasm. In the following program I try to fill a blok of 256 byte's in HUB-ram by Spin and try to read this in a COG programmed in Pasm.
It is not working, what do I wrong:
I try to display each second the next part of the next long on the output-LED's
Another question I have is: When i store data as byte in Hub-ram as followed:
Ram[0] = $H00
Ram[1] = $H11
Ram[2] = $H22
Ram[3] = $H33
Ram[4] = $H44
Ram[5] = $H55
Ram[6] = $H66
And I read it as long, how is it displayed:
long[00_11_22_33] or long[33_22_11_00]
Greetings Abraham.
VAR
byte temp
byte Rom[257]
PUB Start_1 | errorString
Rom[256] := 128 ' bitje mbt laden ROM
Temp := 0
repeat 250
Rom[temp] := temp
temp := temp + 1
waitcnt(80_000_000 + cnt) ' Wacht 1 seconde
cognew(@Rom_test, @Rom) ' Start de "Rom_test" Cog
repeat ' Never stop
DAT
org 0
Rom_test mov dira, led ' Maak LED uitgang
mov outa, led ' Zet LED AAN (= toggle)
xor outa, led ' Toggle/Knipper LED
mov lus1, #0
mov lus3, #100
wacht mov mem, par
begin add mem, #lus1 'or #1 ??
rdlong uit, mem
add lus1, #4 ' verhoog lus1 met 4 = next long
mov outa, uit ' display LED
mov lus2, #pauze ' 20_000_000 * 4 clockpuls = 1 Second
vertr sub lus2, #1 wz
if_nz jmp #vertr
sub lus3, #1 wz
if_nz jmp #wacht
mov lus3, #60 ' 60 numbers to Go
jmp #wacht
{Hier staan de declaraties van de variable} '
led long %00000000_00000000_00000000_11111111 ' output
pauze long 20_000_000
tijd long 100
lus1 res 1
lus2 res 1
lus3 res 1
uit res 1
mem res 1
fit
Ram[0] = $H00
Ram[1] = $H11
Ram[2] = $H22
Ram[3] = $H33
Ram[4] = $H44
Ram[5] = $H55
Ram[6] = $H66
Greetings Abraham.
Your PASM code has some little mistakes so I just show a corrected version with some hints.
VAR long temp byte Rom[257] PUB Start_1 | errorString Rom[256] := 128 ' bitje mbt laden ROM ' ************************************************************************* Temp := 0 repeat 250 Rom[temp] := temp temp := temp + 1 waitcnt(80_000_000 + cnt) ' Wacht 1 seconde cognew(@Rom_test, @Rom) ' Start de "Rom_test" Cog waitcnt(80_000_000 + cnt) ' Wacht 1 seconde repeat ' Never stop ' ************************************************************************* DAT org 0 Rom_test mov dira, led ' Maak LED uitgang mov outa, led ' Zet LED AAN (= toggle) xor outa, led ' Toggle/Knipper LED '<-- Not necessary: The LEDs are too short ON to see it ' OUTA is already cleared at start of a cog mov lus1, #0 mov lus3, #100 wacht mov mem, par '<-- Start with first Address of array begin rdbyte uit, mem '<-- You should read a byte array with RDBYTE add mem, #1 ' next byte mov outa, uit ' display LED mov lus2, pauze ' 20_000_000 * 4 clockpuls = 1 Second '<-- #pauze will give you the address, not the value 20000000 vertr djnz lus2, #vertr '<-- decrement and jump in one Instruction = 4 clocks sub lus3, #1 wz '<-- in two instructions = 8 clocks if_nz jmp #wacht mov lus3, #60 ' 60 numbers to Go jmp #wacht '====================================================================== {Hier staan de declaraties van de variable} ' ' led long %00000000_00000000_00000000_11111111 ' output pauze long 20_000_000 tijd long 100 lus1 res 1 lus2 res 1 lus3 res 1 uit res 1 mem res 1To your second question:
Ram[0] is in the lowest byte
Ram[3] is in the highest byte
How it's displayed depends on the display routine
Andy
Hello Andy.
Thanks for your sugestion's, I go use it.
Greeting Abraham
Hello Andy.
Thanks voor your time and advice. This little step works so I go to set the next one. When I have made progress with my system i let it now.
Greeting Abraham.
For example, your initial loop gets compiled to code that looks like:
Note that the object access model used by spincvt may not always be the same as that in the original Spin interpreter (for example, local variables are usually turned into COG addresses rather than placed on the stack). But spincvt can compile the whole program into a .binary file, which can then be run just like a Spin .binary file, but 10x faster (and probably 3x larger in size).
