USB and 9 pins SERIAL CONNECTOR
in BASIC Stamp
Hi guys. is it possible that bs2 can combine the connection of USB connector and 9 pins SERIAL? we have a device that uses two connections. that is USB for exporting an mp3 files and 9 pins serial for syncing and programming the schedule. by the way our device is called the ANNUNCIATOR. anyway my goal is to use only one connection and that is the USB connector. is there a way that I can do both process in USB cable only? is the bs2 can do it? Thanks!
Even if it was possible the BS2 does not have the memory or processing power to do both, although it might be able to send the serial data for sync and programming.
Please see attachment. Thank you!
