hardware help — Parallax Forums
hardware help
Im running bs2 boe-bot with romming with ping, emic 2, grapler on the bot. I have ping servo mounted on top of the bot's board. it is about 8 inch. tall. The dinning room chair's have a wooden support from one leg to another leg. that is 7 inch. tall. and yes it clothesline it self. lol is there a Learning board out there? I thot of putting a ir receiver & a ir led. to it.
  • ercoerco Posts: 20,257
    edited 2016-06-17 02:02
    Are you asking about adding an IR sensor to detect and avoid the chair rung? You can add more like your Boebot comes with, but your overhead is starting to pile up, your BS2 is already pretty busy running 3 servos, PINGing and potentially using 2 IR sensors already. I'd recommend a premade module, if that's what you mean. They're only a couple dollars on Ebay. http://www.ebay.com/itm/182118560631 As a bonus, it only uses one pin, compared to 2 for an IR LED and receiver.
    ' File...... RoamingWithPING.bs2
    ' Purpose... Roam And Scan Using PING))) Mounting Bracket
    ' Author.... Parallax, Inc.
    ' E-mail.... support@parallax.com
    ' Started...
    ' Updated... 12-21-2005
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    ' {$PORT COM7}
    [ Program Description ]
    ' This programs demonstrates roaming with the Parallax PING))) Mounting
    ' Bracket, which allows you to pan-scan with your Parallax PING))) sensor.
    ' This program assumes you have already set your BOE-Bot up for roaming
    ' with IR sensors. You must also have the PING))) Mounting bracket
    ' installed as per the instructions, with the servo connected to P14 and
    ' the PING))) sensor connected to P15.
    ' Due to the way the PING))) bracket mounts you may have to trim your IR
    ' detectors down so that they don't stick up in the way of the moving
    ' PING))) bracket as it rotates. It's best to angle them off at 45
    ' degree angles so that the BOE-Bot doesn't run into anything while
    ' moving along a wall at a narrow angle.
    ' The BOE-Bot will now roam around and when it senses an object, it will
    ' scan within a 180 degree field of view for the clearest path, which it
    ' will then navigate scanning for an object again. The IR Sensors prevent
    ' hitting a wall when coming at it from a narrow angle where the PING)))
    ' might have trouble seeing it due to the lack of reflection of sound.
    ' Calibration is important to this code working properly. If you do not
    ' have the correct values for your servos then you may get strange results
    ' from your BOE-Bot. The necessary calibration information is listed in
    ' each section of the code where it is required.
    [ Revision History ]
    ' This code is basically a modified version of the Roaming With IR code
    ' from the Robotics With The BOE-Bot Manual, written by Andy Lindsay.
    ' Much of the original code was left untouched so you can see how it was
    ' altered.
    [ I/O Definitions ]
    Piezo PIN 4 ' Piezo Speaker
    RightServo PIN 12 ' Right Servo
    LeftServo PIN 13 ' Left Servo
    PingServo PIN 14 ' PING))) Servo
    Ping PIN 15 ' PING))) Sensor
    [ Variables ]
    irDetectLeft VAR Bit ' Variable For Left IR Input
    irDetectRight VAR Bit ' Variable For Right IR Input
    pulseCount VAR Byte ' Used For Measuring Turns
    distance VAR Word ' Current Distance Of Object
    oldDistance VAR Word ' Old Distance Value
    counter VAR Word ' PING))) Cycle Counter
    task VAR Nib ' Current Task
    [ Initialization ]
    FREQOUT Piezo, 2000, 3000 ' Signal Program Start/Reset
    [ Program Code ]
    Main:
    DO
    FREQOUT 8, 1, 38500 ' Emit 38.5 kHz IR To Left
    irDetectLeft = IN9 ' Store IR Detection Values
    FREQOUT 2, 1, 38500 ' Emit 38.5 kHz IR To Right
    irDetectRight = IN0 ' Store IR Detection Values
    IF (irDetectLeft = 0) AND (irDetectRight = 0) THEN
    GOSUB Ping_Around ' Object Detected via IR Forward
    ELSEIF (irDetectLeft = 0) THEN
    GOSUB Ping_Around ' Object Detected via IR Left
    ELSEIF (irDetectRight = 0) THEN
    GOSUB Ping_Around ' Object Detected via IR Right
    ENDIF
    counter = counter + 1 ' Increment Passive Counter
    IF counter > 10 THEN ' Wait For 10 Servo Pulses
    GOSUB Ping_Out ' Activate PING)))
    ENDIF
    IF (distance > 30) THEN ' Is Object Farther Than 30 cm?
    GOSUB Forward_Pulse ' If Yes Go Forward
    ELSE
    GOSUB Ping_Around ' Otherwise Scan For Clear Path
    ENDIF
    LOOP
    [ Subroutines ]
    ' * USE THE APPROPRIATE PULSOUT VALUES TO MAKE YOUR BOE-BOT MOVE FORWARD *
    ' * WHILE THE PING))) IS FACING FORWARD. *
    Forward_Pulse: ' Send A Single Forward Pulse
    PULSOUT PingServo, 750 ' Ping Servo Forward Pulse Value
    PULSOUT LeftServo, 850 ' Left Servo Forward Pulse Value
    PULSOUT RightServo, 650 ' Right Servo Forward Pulse Value
    PAUSE 20 ' Refresh Delay
    RETURN
    ' * USE THE APPROPRIATE PULSOUT VALUES TO MAKE YOUR BOE-BOT TURN LEFT 90 *
    ' * DEGREES. USE THE SAME VALUE AS ABOVE FOR THE PING))) BRACKET SERVO. *
    Turn_Left: ' Left Turn, About 45 Degrees
    FOR pulseCount = 0 TO 7 ' Number Of Pulses To Turn
    PULSOUT LeftServo, 650 ' Left Servo Left Pulse Value
    PULSOUT RightServo, 650 ' Right Servo Left Pulse Value
    NEXT
    RETURN
    ' * USE THE APPROPRIATE PULSOUT VALUES TO MAKE YOUR BOE-BOT TURN RIGHT 90 *
    Turn_Right: ' Right Turn, About 45 Degrees
    PULSOUT LeftServo, 850 ' Left Servo Right Pulse Value
    PULSOUT RightServo, 850 ' Right Servo Right Pulse Value
    NEXT
    RETURN
    ' * USE THE APPROPRIATE PULSOUT VALUES TO MAKE YOUR BOE-BOT MOVE BACKWARD *
    Back_Up: ' Back Up
    FOR pulseCount = 0 TO 40 ' Number Of Pulses To Backup
    PULSOUT LeftServo, 650 ' Left Servo Backup Pulse Value
    PULSOUT RightServo, 850 ' Right Servo Backup Pulse Value
    NEXT
    RETURN
    Ping_Out: ' PING)))
    counter = 0 ' Reset Passive Delay Counter
    LOW Ping ' Force PING))) Line Low
    PULSOUT Ping, 5 ' Activate PING))) Pulse
    PULSIN Ping, 1, distance ' Receive Return Pulse
    distance = distance ** 2257 ' Calculate Distance
    RETURN
    Ping_Around: ' Start 180 Degree Pan-Scan
    oldDistance = 30 ' Current Old Distance Values
    task = 0 ' Current Task Priority
    ' * USE THE APPROPRIATE PULSOUT VALUE TO MAKE YOUR PING))) *
    ' * TURN 90 DEGREES LEFT. *
    FOR pulseCount = 0 TO 20 ' Number Of Pulses To Spin
    PULSOUT PingServo, 1085 ' Ping Servo 90 Left Pulse Value
    PULSIN Ping, 1, distance ' Receive Distance Value
    NEXT
    distance = distance ** 2257 ' Calculate Distance In cm
    IF distance > oldDistance THEN ' Is distance > Last Clear Path
    oldDistance = distance ' Update oldDistance Value
    task = 1
    ENDIF
    ' * TURN 45 DEGREES LEFT. *
    PULSOUT PingServo, 850 ' Ping Servo 45 Left Pulse Value
    NEXT
    task = 2
    ENDIF
    ' * TURN 45 DEGREES RIGHT. *
    PULSOUT PingServo, 400 ' Ping Servo 45 Right Pulse Value
    NEXT
    task = 3
    ENDIF
    ' * TURN 90 DEGREES RIGHT. *
    PULSOUT PingServo, 225 ' Ping Servo 90 Right Pulse Value
    NEXT
    task = 4
    ENDIF
    ON task GOSUB Task0, Task1, Task2, Task3, Task4
    distance = 50 ' Prevent Scan From Looping
    RETURN
    Task0: ' Forward Was Clearest Path
    GOSUB Turn_Right ' This Could Mean Narrow Path
    GOSUB Turn_Right ' So We'll Turn Around
    GOSUB Turn_Right ' You Can Change The Behavior
    GOSUB Turn_Right ' Of Any Of The Tasks
    RETURN
    Task1: ' 90 Degrees Left Was Clearest
    GOSUB Turn_Left
    GOSUB Turn_Left
    RETURN
    Task2: ' 45 Degrees Left Was Clearest
    GOSUB Turn_Left
    RETURN
    Task3: ' 45 Degrees Right Was Clearest
    GOSUB Turn_Right
    RETURN
    Task4: ' 90 Degrees Right Was Clearest
    GOSUB Turn_Right
    GOSUB Turn_Right
    RETURN
    " Will it work with activity board (WX) bot?
  • Danow wrote: »
    You can't run PBASIC code on a Propeller (Activity Board) but anything a Basic Stamp can do can be done with a Propeller.
    The Propeller is a great microcontroller for robotics. The multiple processors allow one to monitor sensors while simultaneously controlling servos and motors.
    Eventually I will convert this to C code. I want to make sure it (ported code) is compatible with the calibration used on the ActivityBot first.
