Control a wifi sony camera with API
laurent974
Sony has published the API of their wifi camera.
here is the list of cameras that can be controlled
https://developer.sony.com/develop/cameras/
i coded a little snippet to control my DSC-HX60V with my activity bot. Here is the code.
Further ideas are imaginable: timelapse, shoot picture after sound impact (exemple at photoduino), travelling....
Note: To use it you 'll have to configure your xbee wifi (@IP of your camera, SSID and pwd). Beware port is in hex (8080=$1F90)
you can find the SDK here
https://developer.sony.com/downloads/cameras/sony-camera-remote-api-beta-sdk/
CON
_clkmode = xtal1 + pll16x 'Use crystal * 16
_xinfreq = 5_000_000 '5MHz * 16 = 80 MHz
' Set pins and Baud rate for XBee comms
XB_Rx = 7 ' XBee DOUT
XB_Tx = 6 ' XBee Din
XB_Baud = 9600
' Set pins and baud rate for PC comms
PC_Rx = 31
PC_Tx = 30
PC_Baud = 115_200
' line
CR = $0D
LF = $0A
DAT
' value to customise to your camera
httpHost byte "192.168.122.1:8080",CR,LF,0 ' change to your Sony IP Address
VAR
long stack[50] ' stack space for second cog
OBJ
PC : "FullDuplexSerial"
XB : "FullDuplexSerial" 'XBee communication methods
PUB Start
Init
HttpPrint (@json_GetVersion)
HttpPost (@json_GetVersion)
HttpPrint (@json_startRecMode)
HttpPost (@json_startRecMode)
waitcnt(clkfreq * 3 + cnt) 'pause 3 s
HttpPrint (@json_actTakePicture)
HttpPost (@json_actTakePicture)
waitcnt(clkfreq * 5 + cnt) 'pause 3 s
HttpPrint (@json_stopRecMode)
HttpPost (@json_stopRecMode)
Pub HttpPrint(strAddr)
PC.str(string(CR,LF,CR,LF,"-----> Request sent"))
PC.str(string(CR,LF,"POST /sony/camera HTTP/1.1",CR,LF,"Host: "))
PC.str(@httpHost)
PC.str(string("Accept: */*",CR,LF,"Content-Type: application/json",CR,LF))
PC.str(string("Content-Length: "))
PC.dec(strsize(strAddr)-8)
PC.str(strAddr)
PC.str(string(CR,LF,CR,LF,"<----- Answer received",CR,LF))
Pub HttpPost(strAddr)
XB.str(string("POST /sony/camera HTTP/1.1",CR,LF,"Host: "))
XB.str(@httpHost)
XB.str(string("Accept: */*",CR,LF,"Content-Type: application/json",CR,LF))
XB.str(string("Content-Length: "))
XB.dec(strsize(strAddr)-8)
XB.str(strAddr)
PUB Init
PC.start(PC_Rx, PC_Tx, 0, PC_Baud) ' Initialize comms for PC
XB.start(XB_Rx, XB_Tx, 0, XB_Baud) ' Initialize comms for XBee
cognew(XB_to_PC,@stack) ' Start cog for XBee--> PC comms
PC.rxFlush ' Empty buffer for data from PC
Pub XB_to_PC
XB.rxFlush ' Empty buffer for data from XB
repeat
PC.tx(XB.rx) ' Accept data from XBee and send to PC
DAT
json_GetVersion
byte CR,LF,CR,LF
byte "{"
byte 34,"version",34,":",34,"1.0",34,","
byte 34,"id",34,":1,"
byte 34,"method",34,":",34,"getVersions",34,","
byte 34,"params",34,":[]"
byte "}",CR,LF,CR,LF,0
json_startRecMode
byte CR,LF,CR,LF
byte "{"
byte 34,"method",34,":",34,"startRecMode",34,","
json_actTakePicture
byte CR,LF,CR,LF
byte "{"
byte 34,"method",34,":",34,"actTakePicture",34,","
json_stopRecMode
byte CR,LF,CR,LF
byte "{"
byte 34,"method",34,":",34,"stopRecMode",34,","
│ TERMS OF USE: MIT License │
│Permission is hereby granted, free of charge, to any person obtaining a copy of this │
│software and associated documentation files (the "Software"), to deal in the Software │
│without restriction, including without limitation the rights to use, copy, modify, │
│merge, publish, distribute, sublicense, and/or sell copies of the Software, and to │
│permit persons to whom the Software is furnished to do so, subject to the following │
│conditions: │ │
│The above copyright notice and this permission notice shall be included in all copies │
│or substantial portions of the Software. │
│THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, │
│INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A │
│PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT │
│HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION │
│OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE │
│SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. │
