June 2016 Nut and Volts and a Prop 1 (Home automaion ZigBee)
JohnR2010
in Propeller 1
The June 2016 Nuts and Volts features my article on how to use a Propeller and a xBee ZB with SmartThings to drive an analog panel meter. It made the cover!
Click to see article
We may need to try some analog meters and gauges to give her some foundation in history!
Thanks for automating our coop too! ;-)
Well you will find some of your code! I have Adafruit WS2812 LEDs along the top and use your driver! Thanks for sharing.
Thanks Peter! Just as an FYI you and Tracy helped me work out the details on a power circuit for another ZigBee battery powered project this time last year. Well it has been running over 9 months on one 9v battery in test mode. If it makes it to the year point I'm going to write it up. That was one of the most challenging projects I have done! Thanks again for your help!!
I would go with the xBee ZB SMT Digi Part # XB24CZ7PIS-004
Thanks, I just found this article you did today and was going to try it out soon. I think this part for Pro is the same but better range.
http://www.digikey.com/product-detail/en/digi-international/XBP24CZ7UIS-004/602-1241-ND/3026313
