Need Kynar or Piezoelectric Film — Parallax Forums
Anybody have a source or sample? I need about a 3" square piece. Digikey has sample sheets over $100 each, too rich for my blood. Basically I need a drum head kinda membrane that outputs voltage when deflected by a slight pressure, not quite a microphone but close. Any thoughts? I think standard flex sensors are small pieces of this film laminated in plastic, but I need a much bigger piece for the sensitivity I need.
    edited 2016-05-25 02:13
    Possibly an issue with terms here, so let's get those straight first. Flex sensors like this:
    https://www.parallax.com/product/30056
    aren't Kynar, but the vibration tabs like this one are:
    https://www.parallax.com/product/605-00004
    There is a difference in output. As I'm sure you know, flex sensors provide a constant output, while piezo film sensors act like any other piezo device, providing an output only during a physical change of its surface properties, such as bending.
    In general, the larger the sheet of this stuff, the less easy it is to work with. It all needs a bias of some kind, such as the moment mass on the end of some versions of the vibra tab. It acts as an amplifier to what is usually a very small produced voltage.
    You might actually have better luck attaching one of these smaller tabs, with or without the little weight, to a bigger flexible sheet, such as very thin surgical rubber. Let the rubber pick up the vibrations, which in turn will activate the sensor.
    These are the people that sell the sensorized version of Kynar film:
    http://www.meas-spec.com/piezo-film-sensors/piezo-film-elements.aspx
    If you are working on a product prototype that could yield sales orders for them, you might consider contacting an application engineer there, and discuss what you might need.
    You can get the raw film from many places, such as Ridout plastic. But you really don't want to be trying to turn into these into useful sensors, and bonding electrical terminals to it.
    (I don't know if the stuff Phil linked to is actually Kynar, or just some film Epson used to sell for printing silkscreen positives. The type of printer used is an Epson piezo printer, piezo as in the technology used in the printhead. Phil could elaborate if this is Kynar film, and if it is, as long as you don't get into a bidding war, a low-ball price might be worth it.
    edited 2016-05-25 02:50
    @PhiPi: Yup, I saw that, but it's just special printer paper.
    @Gordon: Yup, I saw that, and already requested meas-tech to contact me. Yup, it's for a prototype. Ohhhh, something big is afoot at ercolabs!
    Thank you both, my good men!
    Also looking at thin film speakers & such to see if that may be a source. Dangit, I used to have the perfect size sample of real Kynar at Mattel from 20 years back, but that got lost in the shuffle.
    edited 2016-05-25 04:52
    That old and it might not be any good now anyway. I had some samples from the mid to late 80s that oxidized or were otherwise affected by age/atmosphere/whatever. I had sheets of uncoated pieces, and on all of them, they took on a kind of tarnished look. It was impossible to bond any kind of wires to it, and expect a decent electrical connection. I threw it all away.
    One of the samples I had was the infamous speaker/microphone sheet. The trick with that was suspending it in such a way that allowed for mechanical freedom. What happens is that the sheet won't produce an output at any place it's mechanically attached to a support.
    Not knowing your application or price point, perhaps you might also want to consider something like this:
    http://www.worthpoint.com/worthopedia/edmund-scientific-co-1960s-musicvision-3-items
    Combine a small front surface mirror mounted on a thin sheet of silicone rubber, a 40 cent laser, and a photodetector with the proper lens, and you have a very good microphone, thump sensor, or vibration sensor that can fit into a very small space. Unlike MusicVision, which was intended to reflect colored light into the room or onto a screen, it would have the advantage of being able to be made into a sealed unit.
  • LeonLeon Posts: 7,620
    edited 2016-05-25 10:19
    I remember experimenting with piezo products from this company when I worked at Xerox Research (UK) many years ago:
    I used one of their sensors for measuring heart rate with it stuck to the chest and attached to a tiny radio transmitter.
    Thanks Leon, Gordon had mentioned meas-spec too. Their small sensors are all over Ebay:
    http://www.ebay.com/itm/5-Piezo-Film-Transducer-PVDF-Fluoropolymer-Vibra-Tabs-50mV-g-Audio-Sensor-Mass-/111946572300
    I just need a big piece of film for my application, which is a toy. It may be a bad sign that it is hard to find. Most things get cheaper and more available as time goes by, but that isn't the case here.
    The only alternative materials I can use for this project are Unobtainium and Byzanium.
    Best & cheapest options I found so far at http://www.imagesco.com/piezoelectric/
    $42 Film and $75 speaker
    I need to cut a hole in the middle. Wonder if that would ruin...?
    edited 2016-05-25 19:08
    Probably won't ruin it, but it'll make a gaping hole in the sound. You won't be able to hear Ringo sing, though John, Paul, and George will come through just fine. Ringo didn't sing on that many songs, so it won't matter as much. Though it makes Yellow Submarine a little challenging to follow.
    Piezo technology is used heavily and is pretty cheap. This stuff is speciality -- hence the name of the company that promotes it -- and it is expensive. I've never used anything large; just the small tabs that can be attached to bigger things. When those bend and deflect, the material acts as an amplifier for the film, making the signal even more pronounced. Usual concept of mechanical advantage, and all that.
    I'm using it more as a mike than speaker.
    Seems kinda funny that here's a whole replacement 7" touch screen for $1.76 and I can hardly find piezo film that size under $100.
    http://www.ebay.com/itm/Replacement-Digitizer-Touch-Screen-Lens-Panel-Glass-For-7inch-Tablet-MID-LO-/162051763867
    erco,
    What actually is the requirement here?
    Good old carbon telephone mics were exactly a "membrane that outputs voltage when deflected by a slight pressure".
    I guess my question is do yo need a pressure sensor, basically a DC coupled device.
    Or something more percussive, an AC coupled device ?
    There must be ways to do this capacitively, or magnetically.
    I need a big strong cheap lightweight panel to detect a small impact and output a voltage spike. Other output signals might work, but a piezo spike can feed directly into a micro input pin with little or no hardware per https://solarbotics.com/download.php?file=487
    I'm not sure but I got the impression that whacking on a cheap accelerometer now a days would be, well, a cheap solution.
    Mechanically arranging that might be an issue. Can you use the PCB the accelerometer is soldered to as the membrane?
    No PCB, this is a standalone external sensor. Needs to be cheap, rugged, accurate. I know, pick two...
    edited 2016-05-26 00:42
    Brass piezo disks are dirt cheap: http://www.ebay.com/itm/10PCS-15mm-Piezo-Elements-Sounder-Sensor-Trigger-Drum-Disc-CA-/262433309308
    I'm gobsmacked that one Vibratab is $6 or more on Ebay: http://www.ebay.com/itm/PVDF-Fluoropolymer-Piezo-Film-Tab-Vibratab-50mV-g-Audio-Transducer-/261758457949
    Or at best, 5 for $27: http://www.ebay.com/itm/5-Piezo-Film-Transducer-PVDF-Fluoropolymer-Vibra-Tabs-50mV-g-Audio-Sensor-Mass-/111946572300
    How much could that tiny piece of film cost? I'm surprised China isn't selling ten for a buck. What that country needs is a good 10-cent sensor.
    At $2.50, Parallax's Vibratab is a conspicuous value: https://www.parallax.com/product/605-00004
    But that's moot since their cheapest shipping option is $12.71. Pretty sad since they would easily fit into an envelope and mail for 47 cents. :(
    edited 2016-05-26 02:51
    How about doubly-metalized film, instead of a piezo film? It would form a capacitor, which you could keep charged through a resistor. If the film got distorted, the capacitance would change, causing an instantaneous change in voltage, which could then be read via a capacitive coupling.
  • Page 567. I show how to use a small Kynar tab on a larger strip of plastic to detect even a slight depression of an arc-shaped plastic front bumper. (Though I'd expect you to improve on the circuit, which is very generalized.) I made the bumper out of report cover plastic from the dollar store. In your case, you only need to detect deflection in any part of a suitable substrate, which could be very thin rubber, plastic, whatever. The sensor, attached to the substrate, will pick it up -- except when something goes through that hole and doesn't strike the membrane.
    At commercial quantities, you will be able to get the tabs for much less. Your application does not require the mass, so no need to look at those. Any factory in China would be able to build a jig for attaching the wire terminals, so all you need to spec is the basic film. You don't need to guestimate prices on the much more expensive versions with wires or terminals already struck on.
    I wish I still had some tabs that I could send you, because in 30 minutes of playing with these, your brain will kick into high gear with the possibilities. For experimenting, you can attach the stuff to various things using duct tape. No doubt you'll attach some to your forehead, and then slap it.
    At one time, I created a "kitchen band" for an intended article for Make (my editor left the magazine, and I went on to other things). I connected these tabs to plastic forks, paper dishes, the underside of plastic cups, everything. It's all good, and every one of them detected the thumps, bumps, thwacks, and whacks I threw at them.
    Thanks Gordon! Great thoughts all, you're right on "target" :) . I may actually have one or two here, seems like there may have been one included in one of the Parallax Mystery Bags or Grab bags. I should dig through my buried treasures to see if I'm sitting on hidden gold. :)
    edited 2016-05-26 15:40
    There might have also been one or two in the goodies I passed on to you a while back.
    There's also this:
    http://robotoid.com/appnotes/sensors-laser-fiber-whiskers.html
    though it can be so sensitive, that even air movement in the room will trigger it. You'd mount a fiber optic ring around the periphery of the membrane, and set the sensitivity so low that it'll only react to definite concussions of the membrane.
    This plan first appeared in an older book I did in '88. I then discovered several people had applied for patents related to sensors based on lasers and fiber optics. Most of those should be expired by now, but you'll want to check. This method may cost < $1 in quantity. I know you know where to find cheap lasers... For the fiber optics, you'll need to raid that light fountain sculpture you bought from Spencer Gifts for Mrs. Erco's birthday last year.
    Another awesome thought, but I better stay clear of lasers since this is a toy application. As ever, you are a cornucopia of valuable thoughts and I thank you for your insight!
  • Ah, kids LOVE lasers. Small impressionable children and lasers go together!
    My son was about 6 or 7 when we saw Star Trek: First Contact in the theaters. In it, there are some borgs that have penlight lasers stuck to the side of their heads.
    Days after we saw the movie, and as as a joke, my son waited until it was dark, and his mother and I were out in the living room watching TV. He strapped a penlight laser over his ear with a pair of headphones, and then slowly came into the room, borg style. My wife literally shot to the ceiling. If she had cat claws, would have clung there for the rest of the night!
    Anyway, you're probably right about the lasers -- they consume too much power anyway. The piezo solution will draw in the single digit milliamps.
  • @Erco, I have an odd end sheet of the 28µm piezo film that I'd like to send you for your experiments, toying around. Ultimately though a piezo tab at the edge of your drumhead would be more practical I think. Like Gordon says, it is fun stuff. If you run out of ideas, the app notes and tech manual are amazing.
    What I have is a piece of original Penwalt "kynar" film, 28µ NiAl plated, about 3" x 5.5". Not corroded. You'll need copper tape with conductive adhesive (e.g. 3M #1181) to make the contacts. (Penwalt became Amp, then in 1998 they were bought out by Meas-Spec, then in 2014 Meas-Spec became a subsidiary of TE Connectivity. Unlike many other such chains of acquisition, they did retain the technical depth.)
    Amazing, Tracy, WOW! Much obliged. I'll PM you.
  • erco,
    How sensitive do you need? ...and would these work? ... awhile back I bought one hundred 15mm (12kHz) piezo discs for less than $6...
    Yow!
    I remember them. It's nice to know that the firm is still in business.
    Gordon, your book? Which edition?
    erco, new problem. Your robots are busy packing for a visit some place.
    erco,
    Great call Beau! I have a pile of 25mm disks I've been using for experiments. As you showed, very sensitive. I used those on my Knock Box a few years back. Likely too sensitive here since this is on a mobile robot application, it will be moving and vibrating by itself. I need to isolate impacts. Might be a matter of tuning. I won't rule anything out!
    Still waiting to hear back from Meas-Spec about cutting holes and folding their piezo film material.
    Attaching several useful piezo links here which I found in my web searches. Might help someone else. Like Duane, I see this forum as useful place to store info.
    http://www.imagesco.com/articles/piezo/piezo06.html
    https://www.steminc.com/PZT/en/
    http://www.meas-spec.com/contact/distributordetail.aspx?r=650&t=690&s=128
    Until the forum software gets upgraded again or reorganised again. Each time we seem to lose heaps of info :(
