Measuring pulse accurately — Parallax Forums
Hi All,
I would like to measure a rotating disk accurately. I will use a photo-transistor to trigger counter. Should I use two counters?
    muttvac wrote: »
    Hi All,
    Depends on what you are measuring, the programming language, and how fast the disk is turning. Two counters would work for any of those choices.
  • Also how accurate do you need to measure it? The XO driving the propeller will be only accurate to some 10 to 100ppm. Just sayin'.
  • jmgjmg Posts: 15,182
    guenthert wrote: »
    Good point.
    The OP can connect a GPS 1pps to another COG, and measure that too, then calibrate the XO to well under 1ppm.
    Should do for most disk measurements, maybe even thermal expansion ones... ?
  • Thanks all, wind speed not really that fast.
    muttvac wrote: »
    Single counter to count pulses and waitcnt for timing. Spin is fast enough for this so C or pasm would be more than fast enough.
  • If you can measure the time at 2-4 marks around the disk, you may be able to infer the wind direction as well.
    Interesting idea, but would not work with the generic 3-equal-cup wind speed sensors.
    You also need to extract phase info, as well as speed, but maybe a skewed-cup design plus a variant of single-track-gray-code, can give velocity wobble with enough phase information to get wind direction ?
    Elevates the timing from fairly trivial, to something more Prop like :)
  • Just use motor minder
    It looks for a positive edge to trigger counter b, just change it if you need too.
