Why is PINGETZ/RDPIN/whatever not an implicit PINACK? — Parallax Forums
I can understand needing a separate ACK instruction for when you don't need to read from the pin (e.g. serial tx). But, is there a reason you would not want to ACK a pin when you read it?
  • Maybe because multiple cogs can all do a PINGETZ (RDPIN) from any smartpin even if they didn't configure it in the first place.
  • evanhevanh Posts: 17,289
    edited 2016-05-13 14:08
    Multiple Cogs, that aren't synchronised, reading one Smartpin would have some messy gotchas I'd think. On that note, it would make quite good sense for a RDPIN to reset the IN signal.
  • From another thread "Shared Smartpins" Chip said
    All cogs can simultaneously do PINGETZ on the same pin, but PINSETx/PINACK to the same pin cannot be from multiple cogs at once
  • jmgjmg Posts: 15,200
    Seairth wrote: »
    I think this could vary with MODE.
    For simple data-flow, as in the new DAC-Path, it makes sense to ACK-on-Read.
    However, with hardware pin actions, there is a limited signaling set between COG and PIN, and some means to separately READ and Re-Arm could be needed with HW Pin Cell use.
