Modbus master for Propellor Spin — Parallax Forums
I am very new to Propellor but have some Arduino experience. I have code in Arduino C that uses a Modbus master library (=Object?) that lets me communicate with my solar system controller for a diversion control that I have developed. I would like to change to the Propellor using Spin to communicate with the controller. The Propellor would be the master. I can find 2 slave objects in the object exchange but not a master object. Might there be a modbus master object for Spin already developed that I have not found?
Will
  • The Midnite uses Modbus RTU so that it is an RTU master I am looking for.
    Thanks again
    Will
  • ElectrodudeElectrodude Posts: 1,685
    edited 2016-04-30 20:01
    I have a Spin modbus RTU master. It can be found at http://obex.parallax.com/object/841.
    I used it to talk to a Morningstar MPPT, and it only has the methods I needed for that, which includes Read Multiple Holding Registers, Read Multiple Input Registers, and Write Single Holding Register.
    Note that the serial driver it uses can do 4 serial ports in a single cog. I highly recommend using the 4 port serial driver for all of your serial ports to save cogs. There are some other 4 port serial drivers floating around, and they should probably all work. The one I included has 512 byte receive buffers, which is the biggest of all of the versions I know of.
  • Wow -Thank You Electrodude. The Morningstar uses rs485 while the Midnite uses rs232. I added a second Midnite and want to talk to them both. I am hoping with the Propellor that I can have 2 instances of modbus running - one targeted to each Classic. I think the methods your object has are the ones I need my for control - read multiple holding registers and write single holding register. I am presently using Function 3 - READ_HOLDING_REGISTERS and Function 16 - PRESET_MULTIPLE_REGISTERS to read and write to the Classic with the Arduino. I only write to one register at a time so this object should work for me. Thanks again.
    Will
    I have a Spin modbus RTU master. I'll post it on obex.parallax.com and then update this post with a link to it.
    EDIT: Here it is: http://obex.parallax.com/object/841.
    I downloaded, extracted all the files in the archive, and the serial object looks fine but the modbusmaster file size is zero K and there is no data in it.
    edited 2016-04-30 19:54
    kwinn wrote: »
    I fixed it. Try downloading it again. Thanks.
    I had opened modbusmaster.spin via a symlink, and BST must not have liked that when I made the first Propeller Archive. I opened the original in BST and told it to create a Propeller Archive from that, and then verified that it was all there.
    edited 2016-04-30 20:38
    willeert wrote: »
    Will
    You can certainly have two instances of the modbus library running. But that would require using two of the four serial ports in the serial cog and would also require four IO lines. Also, see the mb.setport method in my library.
    I had to talk to two Morningstars at once (a TS-45 and a TS-60), and I got away with using only one instance of my modbus library with both of them with some circuitry. I don't remember that they used rs485 - I used a rs232 level shifter and it worked fine. First, I gave the two MPPTs different station IDs - I made one station 1 and the other station 2. Then, I hooked the Prop's modbus TX pin into one of TX units of the level shifter chip and sent that output to both MPPTs, and I connected the two receives first through their own units of the level shifter chip, and then I used diodes and a resistor to act as an OR gate. They didn't ever interfere with each other, since only one MPPT was ever transmitting at a time, since they had different station IDs.
    I've implemented methods 3 (readmhr), 4 (readmir), and 6 (writeshr). But since you only write one register at a time, you should be fine with my writeshr function.
    There's a broken implementation of method 16 (writemhr) that's included in my library but is commented out, since it doesn't work. I don't have time now to fix and test method 16. Fixing it shouldn't be too complicated, but I don't have time to test and fix it now.
    Note that part of the reason I have so many helper functions is so that they can abort on error. In Spin, errors can only be caught at function boundaries.
    kwinn wrote: »
    Thanks. Much better.
  • My Propellor board arrived today. I bought the P8X32A Microcontroller QuickStart to learn with. Kind of wish I had ordered the ASC+ but I did not find it until I had already ordered the QuickStart. Waiting now for the 3.3V DB9 Rs232 to TTL converter so I can try RX/TX with my Classic from the Propellor. Also waiting for 2 books to help me learn Spin and how to use the Propellor. Reading the Propellor Manual while I wait....
    Will
  • Page 5 of the Propeller datasheets has a schematic showing a RS232 level converter made from a couple transistors and some resistors.
    I noticed Electrodude's Modbus object uses the serial driver I modified. I personally don't use that driver anymore. I much prefer Tracy Allen's four port object which allows the size of each buffer to be individually set.
    I know some Modbus protocols use even parity. I modified Tracy's driver to use even parity on one of the ports.
    I'll post my version with even parity if there's interest.
    I have a bunch of QuickStart boards myself. For a while I attempted to keep track of some of the projects done with QuickStart Boards in this thread.
    edited 2016-05-03 18:41
    Duane Degn wrote: »
    I'm pretty sure my Modbus object will work with anything descended from Tracy Allen's four port object.
    Why don't you use your driver anymore? It's nice being able to reuse the hub memory that had the cog image. Couldn't you make a version that both lets you individually set the buffer sizes and reuses the cog image in hub ram?
  • Hi Duane
    I would like to see your even parity driver. Thank you. I don't have a lot of experience so the more examples I can look at and compare differences the more I learn. My diversion control modbus configuration is 8N1 so I don't have a parity bit if I understand the configuration correctly. I think that I am going to learn a lot more about Modbus with this project - trying to get the Propellor to read and write to the Classic.
    Thanks again
    Will
    edited 2016-05-04 03:29
    I like to think making a version with individually set buffer sizes and reusable cog image is within my skill set and I may have already done something like that. My "cogject" version of a serial driver requires one to indicate where the buffers are located.
    The attached code adds even parity to port #1. The even parity is not checked with the incoming data. The parity bit is ignored.
    I added a bunch of debugging aids to the attached code. Many of the common methods have copies which allow one to set or clear a lock. For example ".Strs" is very much like a normal ".Str" method but it also sets a log and identifies the cog calling the method. There are other methods with this add "s" which makes it easier to set a lock. Methods with an added "e" clear the lock.
    The object can be included in multiple child objects. The start method should only be called once but other than that, multiple cogs and multiple objects can share the serial driver by making use of the lock.
    I generally try to use a cleaner version of the serial driver in my final code. In general a single cog should be responsible for all serial communication. I try to limit locks on a serial driver to debugging versions of the code.
