Get XML Attributes in SPIN
laurent974
I would like to share a little code after my first journey on the SPIN road.
I didn't find an xml parser for the propeller. But my need wasn't so difficult to code. I just wanted to get the attributes of an xml file.
Since it took me some time to get it right, I post it here it may help others, or you could give me advices to improve it too.
i didn't count how many time i was lost in pointer / address / values with spin. Only using the terminal to debug is really a pain.
| This Obj finds XML attributes and put them into a list of string |
| suppose you have an xml text that provides informations inside attributes like |
| <test> |
| <Day data="Auj"> |
| <Day data="Tom"> |
| </test>" |
| GetXMLATTRIBs will extract all attributes values. Results are stored into a array of strings. |
| Days = "Auj\0Tom\0" |
┌--> get starting position
┌───────-┐ │ ┌---> Days
│ xmltxt │-┘ | │
└──────-─┘ │ ┌--store in global value--┐ dispatch function │
└--> ParseXMLTxt ---> | Values_Array │--------------------┼---> Conditions
└-------------------------┘ GetXMLAttribs │
└---> Icons
NOTE: This file uses a modified version of OBJ string. I added a string copy function
