How to use a spin program using simpleIDE?
So I have been told that you can call a spin program using c in simpleIDE but I haven't been able to find the answer anywhere to how to do it? Any help would be great.
I don't know how to include a Spin program in a C program in SimpleIDE, but it is possible. If you want to run a pure Spin program, you probably want PropellerIDE or Propeller Tool.
I'm not sure you can use it to call actual Spin code directly. You could use the Spin2CPP tool to convert the Spin code to C, and call that, but that's not quite the same thing, and I'm not sure SimpleIDE has support for doing that built in - someone else can answer that bit.
http://forums.parallax.com/discussion/157563/combining-spin-and-c/p1
FullDuplexSerial: No such file or directory
Does anyone have any idea what could be wrong?
