GCC VGA Demo debugging
in Propeller 1
For a larger project, I'm trying to get a feeling for VGA output and am poking around in several of the VGA Demo's in the SimpleIDE package.
I'm running into the following problem:
Compiling and uploading the \Propeller GCC Demos\pong\pong.side project, I get a Pong game (that seems to restart at arbitrary moments) so I know that at least the connection is OK.
Compiling and uploading the \Propeller GCC Demos\vgademo\vgademo.side project, I get no errors, but the screen insists there is no VGA signal.
The line 'VgaStart(2, 30, (int *)tilemap, tiles, &pixelColors, (int *)&syncIndicator);' appears to set the VGA pin-group to '2'. This is the same setting I had to use for the pong game, which worked.
I'm using an old Propeller Proto USB board Rev A.
This board offers a VGA connector at pin 16 and up. (This is why it makes sense that pingroup 2 should work..? )
Does anybody have any experience with the vgademo project and / or any idea how I could debug this? I've tried adding print's to the code, (after adding simpleterm.h even appeared to succeed at this) but even a pause and terminalwrite at the beginning of my main doesn't appear to do anything.
While writing this, I'm digging through the settings and one thing I do notice, is that memtype is:
Doesn't this mean that I have to attach extra RAM to my board / a board called 'BOARD::C3F' has this external RAM? If so, I might well have solved my own problem.... ^_^
Can anybody verify this for me?
>memtype=xmmc external flash code main ram data
Memory model: LMM Main RAM Compact:
Soooo.... Yeah... Back to the drawing board... Maybe I can prune enough stuff out of the code to fit it inside the board...
