Attaching a rocket to by Boe-Bot
in BASIC Stamp
I am a teacher trying to figure out how to launch an Estes model rocket from a pad mounted to a Boe-Bot. It is a six volts igniter, what is the best way to get the power to the igniter. We already tried pin 15 to Vdd lot. We would really like your input for this scenario.
The best way would be using a relay, such as this,
https://www.parallax.com/product/27114
It has been tested with the BS2. I think the 20 AMP should suffice.
EDIT: Link Fixed. It's also on sale!
Thanks David. Link Fixed.
Edit: Didn't find the post I was looking for, but I did find a whole discussion of electronic igniter circuits here: http://forums.parallax.com/discussion/92938/firing-circuit
At one point, read when I first found out about the BOE Bot's crawler treads kit; I had in mind a launcher mounted on the back of a BOE Bot with the crawler tread kit, loaded with a small rocket crawling to the launch point when it gets there, it would wait several seconds. And from there would then launch the thing.
It would then return to the ground crew, read the individual who set the thing up and set it to do all of that.
Then of course the recovery group goes into work recovering it when it finishes its trip.
And since the company makes a series of sensors I originally thought of a whole idea using them the same way. The launcher would not be travelling to the launch point however, since the rocket would be much larger.
I'd say we are moving to a completely different thread now.
