Hi
Use cut pieces of 40 pin headers.
Here is the way I did this on my current project.
You need soldering skills to attach the headers.
You do need a Prop Plug to program it.
I like the Prop Mini.
Here's a graphic I made a while back for a post that I never made. It simply shows the Mini on a breadboard to blink an LED on P0.
Have you downloaded the Propeller Education Kit PDF? I would definitely recommend going through that. Although the Mini wiring is different, if you use the same pin numbers, you can use all of the code examples, etc.
I hope this helps you.
Gary
PE Kit Page:
https://www.parallax.com/product/32305
PDF link:
https://www.parallax.com/sites/default/files/downloads/122-32305-PE-Kit-Labs-Fundamentals-Text-v1.2.pdf
