Strange Problem on Prop LCD controller board
T Chap
In the past when a stack overflows or variables are overwritten, it is pretty easy to track these issues down and the crash is usually obvious about the reasons. I have a Prop controller board that drives and cap touch LCD screen. The code has been stable for a year, then last week I made a lot of changes to the screen adding a menu method of scrolling to options for change versus having dedicated graphic buttons you would touch to access a value to change. The LCD Driver has not changed at all. Over the past week, about 3 different occasions the screen has turned solid white and the piezo buzzer started making a consant screeching sound as if the Prop was sending it random signals versus a steady frequency for beeps.. The instances were all such that the module had not even been touched for many hours( possible last touch was 5 to 12 hours), and while sitting in the main loop there is nothing happening other than reading for touch input info. A stack overflow is usually instant and you can usually find cause and effect relationships by using the device. In this case there is no cause and effect so I am trying to figure out where to start to diagnose. Any ideas on how to chase down a problem like this? The code is to big and messy to post. 7209 longs, 4308 lines of code compiled.
Here is the main loop. It just sits waiting for touch, the omron sensors are disabled in the menu to they are not being read.
PUB RunLoop | h i2c.initialize i2c.StartCapTouch i2c.WriteThreshHold($30) '46 i2c.WritePeak($c0) 'c0 MenuCount~ AllowWatch := 1 AllowAdjust := 1 ValueChange := 2 'neutral value fix ButtonType~ ' ? repeat 'beep2500 ValueChange := 2 'w(10_000_000) ' set loop rate /* ReadOMronA ' *** DISABLED, not even being read still causes crash ReadOMronB ' *** DISABLED, not even being read still causes crash ReadOMronC ' *** DISABLED, not even being read still causes crash tempcount := cnt 'helpclearcounterval := 5000 IF ReadTP== 1 'there a response from a touch CheckMainButtons(touchx/16,touchy/16) ' - / + Menu < > button input PaintMainParts ' print($100) erase screen and add parts back per menu requirements UpdateMenu ' IF MenuChanged == 1 if menu changed ESTABLISH MODE# EnterMode ' Get mode of button pressed then parse the mode USE MODE# 'WaitTouchRelease ' do not wait for release w(5_000_000) 'HelpClearFlag := 1 IF A_on + B_on + C_on == 0 ' if all sensors are off, the loop goes too fast (buttons too fast) helpclearcounterval := 10000 w(10_000_000) elseIF A_on + B_on + C_on ==1 helpclearcounterval := 150 w(4_000_000) elseIF A_on + B_on + C_on ==2 helpclearcounterval := 150 w(3_000_000) elseIF A_on + B_on + C_on ==3 helpclearcounterval := 150 ShowEscapeicon := 1 PaintEsc ButtonType~ AClearA 'A> Trig part 1 clear graphic icon ABClearA AClearB ABClearB ClearContact1 ClearContact2 IF ClearArrayFlag == 1 IF Cnt - ClearArrayCnt > 160_000_000 'beep2500 ClearArrayFlag++ ClearArrayCnt := cnt IF ClearArrayFlag == 2 ' this is a backup plan to clear array IF Cnt - ClearArrayCnt > 160_000_000 'beep2500 ClearArrayFlag~ IF HelpClearFlag == 1 ' set in ReadTP ***RESET SCREEN AFTER X seconds idle*** helpclearcounter++ IF helpclearcounter > helpclearcounterval 'may set this rate based on how many sensors scanned beep2500 ShowEscapeicon~ helpclearcounter~ helpclearflag~ LockStatus := 1 prgmode := 0 ' time out PRG icon input 'ClearProgramScreen ' no longer needed Unlock~ Mode~ ' kill MODE to stop any array edits. MenuCount~ PaintMainParts PaintWatch UpdateWatchValue PaintAdjustSection AllowWatch := 1 IF Watch == 0 IF A_on == 1 PaintArrowGreen PaintBoxNumbers elseif Watch == 1 IF B_on == 1 PaintArrowGreen PaintBoxNumbers elseif Watch == 2 IF C_on == 1 PaintArrowGreen2
http://www.st.com/web/en/resource/technical/document/datasheet/CD00000443.pdf
The 5V LDO claims 16V max. I am using a .1uf, 10uf non electro on both the input and output of the regulators, same design as I have done for years with no issue. Maybe the 12V is the problem. I can't see how this could be going into oscillation. I think the regulator is running too hot so the temp may be affecting the nearby capacitors. I will switch back to the 6VC input.
