char s[9];
Howdy,
I was working on this exercise:
http://learn.parallax.com/propeller-c-simple-circuits/seven-segment-display
and at the bottom the second code example has the line "char s[9];" and I was just wondering what's it for? I removed it and it works fine...
/* Seven Segment.c Display digits on a 7 segment (common cathode) LED display. http://learn.parallax.com/propeller-c-simple-circuits/seven-segment-display */ #include "simpletools.h" // Include simpletools int n[] = {0b11100111, 0b10000100, 0b11010011, 0b11010110, 0b10110100, 0b01110110, 0b01110111, 0b11000100, 0b11110111, 0b11110100}; char s[9]; int main() // main function { set_directions(15, 8, 0b11111111); // P15...P8 -> output pause(1000); for (int i = 0; i < 10; ++i) { set_outputs(15, 8, n[i]); // 0 -> 7-segment display print("n[%d] displayed.\n", i); pause(1000); } }
Thanks, do you maybe have a link of an example of when it's used?
