How to determine power provided by a Class D amplifier
I have a number of different Class D amplifier boards. I noticed that they have different power outputs depending on the voltage applied to the amplifier, the impedance of the speaker, and apparently (?) the frequency of the signal provided to the amplifier. I am using a 4-Ohm speaker in a mono speaker setup.
How can I measure the Power that these boards supply to the audio speaker?
1) Is there some type of low cost Power meter that can be used?
2) Can I measure parameters with a standard VOM that will provide the Power value?
In advance, thank you.
