Activitybot Learn Program --- go forward 256 ticks then turn 90 degrees
Executes program first run, then after pushing reset button runs the straight portion only and continues straight, pause until, maybe, it will initiate 90 degree turn.
You can also try writing your own drive commands and see how it works.
Double check the encoders are over the center of the wheels, and not significantly out of alignment. You can run the program for testing the encoders.
I've also had the bots act pretty goofy on low batteries.
If problems persist, try swapping the board and or servos.
I teach with these things to around 100 students this semester, so needless to say I do a lot of troubleshooting.
I use Costco Kirkland batteries, and I'm about to look in to rechargeables.
