SimpleIDE C function problem
The above tech note is what I am trying to get to work, using SimpleIDE simpletools. When compiled, it does not have any errors, but the value displayed is not what I am expecting. When I have a draw on the battery, I am expecting to see a negative value, but I do not see any negative sign when the value is displayed. Anybody have any ideas as to what I got wrong with my function?Data Bytes: 2
signed
The current in milliamps (mA) flowing into or out of Create’s
battery. Negative currents indicate that the current is flowing
out of the battery, as during normal running. Positive currents
indicate that the current is flowing into the battery, as during
charging.
Range: -32768 – 32767
Ray
void CRcurrent()
fdserial_txChar(create,142);
fdserial_txChar(create,23); // Current
int highbyte = fdserial_rxChar(create);
pause(50);
int lowbyte = fdserial_rxChar(create);
pause(50);
//writeDec(rpi,highbyte); // 255
//writeStr(rpi,"\n");
//writeDec(rpi,lowbyte); // 93
float tempbyte = ((highbyte << 8) + lowbyte);
writeFloat(rpi,(tempbyte/1000)); // 63.0xxx
writeStr(rpi," Current\n");
tempbyte=0;
There are a number of ways to do this, but they all come down to the same thing (copying the high bit of the 16 bits you read into the upper word of the 32 bit register). The simplest and probably clearest is to let the compiler do it for you: This declares the current to be a signed 16 bit quantity (int16_t), so when you cast it to float later the sign extension will happen automatically.
If you don't do this, the calculation of (( highbyte << 8 ) | lowbyte) will happen in normal int precision, which is 32 bits, and since the resulting value will never exceed the positive range of a 32 bit integer it will appear positive. You could also sign extend by hand:
current32 = (int16_t)current32;
It's functionally the same as the double shift, but it tells the compiler (and whoever reads your code) a little more explicitly what you're trying to do
Now, the question I have is, why is the function below working as expected, or maybe it's not, and I am getting values that are close enough, but not really? I used used this function as a basic start for the function in the previous post, but now I am curious as to what the code difference is, in the function below, compared to the previous function, that makes this one work, and the other one not work as expected?
Ray
void CRvolts() { fdserial_txChar(create,142); fdserial_txChar(create,22); //Voltage int highbyte = fdserial_rxChar(create); pause(50); int lowbyte = fdserial_rxChar(create); pause(50); float tempbyte = ((highbyte << 8) + lowbyte); writeFloat(rpi,tempbyte/1000); writeStr(rpi," Volts\n"); tempbyte=0; }In both cases you're reading 16 bits, but in case 1 you want to treat those 16 bits as signed (-32768-32767) and in case 2 you want them treated as unsigned (0-65536). That's why C has different signed and unsigned integer types.
Ray
So using "+" or "|" to set those low bits makes no difference.
There is a reason why in boolean logic they use "." or AND and '+' for OR.
Personally I would rather use the "|".
Using P24 on the Propeller board, which would be connected to Pin 3, would I just:
low(24)
high(24)
or is there a better way to do this. Of course this will be in its own little function.
Ray
