Finding which variable name contains the lowest value — Parallax Forums
I have no problem for multiple variables finding the lowest value (lots of algorithms on StackOverflow).
But I need to display the variable *name* that is holding the lowest. Any suggestions for something better than below?
' ??? for 4 variables named: A, B, C, D containing byte values
' Is below best way to display name of var holding lowest value ?????
IF (A<B) AND (A<C) AND (A<D) THEN
DEBUG "A smallest"
ELSEIF (B<C) AND (B<D) THEN
DEBUG "B smallest"
ELSEIF C<D THEN
DEBUG "C smallest"
ELSE
DEBUG "D smallest"
ENDIF
  • You could move the " smallest" text into a separate DEBUG statement after the ENDIF:
      DEBUG "A"
      DEBUG "B"
    ELSEIF C<D THEN
      DEBUG "C"
    ELSE
      DEBUG "D"
    ENDIF
    DEBUG " smallest"
    You could also replace each of the DEBUG statements with a line that sets a byte variable to "A", "B", "C", or "D" and then put `DEBUG char, " smallest"` after the ENDIF:
    char VAR byte
      char = "A"
      char = "B"
    ELSEIF C<D THEN
      char = "C"
    ELSE
      char = "D"
    ENDIF
    I suspect the first might be both faster and smaller, but I really don't know, so try both if it matters. The second one has the advantage that it leaves the result in char, in case you need it later.
    There's not much else you can do, since variable names don't make it into the tokenized binary that gets sent to the Stamp.
    edited 2016-02-25 19:07
    I like your algorithm. For the sake of variety and PBASIC tricks, here's another.
    smallest VAR Byte
    name VAR Byte
    idx VAR Nib
    smallest = A max B max C max D  ' strangely enough, finds the minimum value
    LOOKDOWN smallest,[A,B,C,D],idx  ' the index of the minimum value
    LOOKUP idx,["A","B","C","D"],name   '  the name associated with that index
    DEBUG "Smallest is: ",name,CR,LF
  • Even smaller:
    idx VAR Nib
    LOOKDOWN A max B max C max D,[A,B,C,D],idx
    DEBUG "Smallest is: ","A"+idx,CR
    edited 2016-02-25 19:08
    (edited my previous post, syntax, lookup and lookdown take square brackets for the argument list.)
    Another possibility is that the names will actually be strings. Here is a way to manage that.
    nameloc VAR WORD
    A VAR BYTE
    B VAR BYTE
    C VAR BYTE
    D VAR BYTE
    char VAR BYTE
    smallest VAR BYTE
    idx VAR NIB
    main:
      DO
      ' gosub findname
      LOOP
    findName:
      smallest = A MAX B MAX C MAX D  ' strangely enough, finds the minimum value
      LOOKUP idx,[aname,bname,cname,dname],nameloc   '  nameloc points to the name
      GOSUB showname
      RETURN
    showname:
      DEBUG "name is  "
      idx=0
      DO
        READ nameloc+idx,char
        IF char=0 THEN EXIT
        DEBUG char
        idx=idx+1
      LOOP
      DEBUG CR
      RETURN
    aname DATA "Peter",0
    bname DATA "Paul",0
    cname DATA "Mary",0
    dname DATA "Rumpelstiltskin",0
