PASM options -- which is best way?
in Propeller 1
I have an application where the main cog is making a PASM cog go to sleep when it is not being used. I am using waitpeq in the PASM and having the main cog (running a C program) use a pin as a flag to turn the cog on and off. The first time the PASM runs I want the cog to run (not wait) and store the pin number / mask as a 32 bit value (into a variable "waitpin"). I've gotten it to work, but I keep on coming up with different options for the test for the first time through. I am limited in what I can do by the way the PASM code is set up.
The code I am using (at this time) is:
Since "add" is unsigned, I shouldn't have any problem adding 0 and storing it back to waitpin
Reading the propeller manual, I see that I could also use "or" or "cmp" instead of "add" all with the wz flag.
"cmp" doesn't write back to waitpin, but the others do unless the nr flag is specified. In this case writing back to waitpin (either 0 or its original value) doesn't seem to be a problem.
Since I'm new to PASM, what would be the best option and why?
Tom
DAT org loop add waitpin, #0 wz ‘’ waitpin is the 32 bit pin mask ‘’ first time through “waitpin” is zero, subsequent times it is a pin mask non-zero if_nz waitpeq waitpin, waitpin ‘’ sleep til other cog sets waitpin high … do PASM stuff (first time through jmp to #startup, initialize stuff, put pin value in waitpin) … do more PASM stuff … jmp #loop … waitpin long 0
Tom
do PASM stuff
waitpeq ' cog will shutdown until port = mask (or your variant as required)
jmp #loop
I recommend that you look at the LOCKxxx instructions (and corresponding Spin statements) to signal among cogs. If a lock is set, the PASM cog can continue, otherwise it continues to check the lock. When it's finished its work, it can clear the lock. The Spin code requests a lock during initialization and clears it. When the Spin code wants the PASM cog to do its thing, it sets the lock and waits for the PASM cog to clear it when it's done.
The reason I want to wait the cog is to reduce the power used for a battery powered application so having it check for a lock won't do that.
When the main cog starts the PASM cog it passes a command variable through "par". The variable has 4 parameters packed into the 32 bit variable. One parameter is 3 bits containing the pin number that will be converted into the 32 bit pin mask and stored into waitpin. The first time through waitpin should be 0 since that is how it is declared in the assembly language program:
"waitpin long 0".
As I mentioned above the program as written does work. I tested it by adding some temporary code that turns off an LED just before the waitpeq instruction and turns it back on just after. The LED lights for a split second and turns off for 10 seconds which is what the main cog is calling for.
I'm just trying to figure out the best way to do the test before the waitpeq.
Thanks again
Tom
org 0 start mov temp,PAR ' get parameters ' shr temp,#xxx ' use if pin# not least significant ' and temp,#$1F ' now assume pin# in bits 4-0 shl waitpin,temp ' shift mask into place (only uses bits 4-0 for #shifts) loop waitpeq waitpin,waitpin ' wait for I/O pin to be high ' .... do stuff ' .... make sure the I/O pin is low before jumping back to loop ' .... either set it low here (if appropriate) or wait for it to be low ' .... if some other cog is setting it low jmp #loop temp long 0 waitpin long 1cmp is probably the clearest to read, since you are in fact comparing the value to 0 and not trying to change it. But as you point out all of those options would work.
