Solder stencil trick
I just made this 1/4" PCB holder tonight using acrylic. I used the PCB hole locations that were in the stencil for each board and drilled a hole to insert a 6-32 set screw. I use a .14" mounting holes in my boards, so the 6-32 fits perfectly as it is just under .138". This makes for very fast board placement for the screen with very minor tweaks if any to adjust the screen. I had already done the same type of base for the PNP. Making individual boards is super fast with this concept.
