QuickStart Programming Issue
in Propeller 1
I'm working with a Propeller QuickStart, RevB board. I loaded a program onto the EEPROM, disconnected the USB connection and was using the board powering it from a Power Supply for experimentation. After running the experiment I realize I had to make a change to the program. I powered down the QuickStart board, connected the USB connection to download the revised program. However, now when I try to download, the "No Chip Found On Any Serial Port" & "Unable to Open Com7" message comes up. If I disconnect the board and power it from the Power Supply the original program still is functioning. When it was connected to the USB I tried reset just to see if I could get the Propeller Tool to identify the board, but the same message comes up. Is there a way to correct this so I can reprogram the board?
Thanks for your help.
Brian
Brian
Did you have any debug messages in the program? If so, do these messages display in the terminal window?
If you have lots of debug messages, it can cause a problem for Windows as it tries to open the com port to connect with the Propeller. If this is the problem, you can get around it by pressing reset half a second before attempting to program the Prop with F10 or F11.
If you have too many comm ports, sometimes windows has a problem.
"Too Many" could be more than 20, but some times it could be more than two.
I used the following in a batch.bat file to unistall all comports.
They automatically reinstall on next insert.
Again, thank you for the suggestions!!!
Brian
