Give me a sign — Parallax Forums
Give me a sign
I've been playing with this so long... it has become a blur.
I have a nifty BNO055 absolute position sensor with sensor fusion. It reports linear acceleration as signed 16bit integers.
When I display these values over serial, the signs are lost. Actual negative values are reported as the two's complement form... and appear as positive values. And if I do arithmetic on these values, the result appears as though the two's complement form of the negative values is actually a positive integer being operated upon.
What to do?
  • sounds like your prpgram is interpreting the values as 32-bit or 16-bit unsigned. can we see your code?
  • Yeah it might be a sign extension issue. A negative number would need the upper 16 bits set to $FF. I'm pretty new to Prop, but something like:
    NegMask = $0080
    if ReadValue AND NegMask = $0080
    then OR ReadValue, $FF00
    should work. You know what I'm saying :P
  • JonnyMacJonnyMac Posts: 9,566
    edited 2016-01-08 01:31
    Make sure your variables are longs, then do this:
    ~~sensorvalue
    Yep, that's it. The ~~ at the front of a variable extends the sign from bit 15 (a single ~ extends from bit 7).
  • rjo__rjo__ Posts: 2,114
    David,
    I had trouble figuring out which version to show you... but your question got me looking and Iit turns out that I was declaring a long but bit shifting it as though it were a word... duh.
    I also discovered that if I declare a variable as a word and then assign a -1 to it, what comes back is the two's complement form... but for as a long it comes back as -1... who would have figured?
    I don't have it completely sorted yet, but this appears to be my first mistake.
    Rich
    edited 2016-01-08 01:39
    gis667en11 wrote: »
    NegMask = $0080
    Your example is actually showing extension to a 16-bit value from a signed 8-bit number. In Spin you need to use longs for correct results with signed operations. Here's a way to do what you're suggesting if the special operator is not your cup of tea.
      if (sensorvalue & $8000)
        sensorvalue |= $FFFF_0000
    Another what to so this in Spin -- if the sign is not in in bit 15 or bit 7 -- is like this:
    (sensorvalue << (31 - SIGN_BIT)) ~> (31 - SIGN_BIT)
    The ~> (SAR, shift arithmetic right) works like a right shift but fills bit 31 with the previous contents of bit31 (instead of 0 as a standard shift does).
    This is what I ended up with... all variables are long. The signs and magnitudes seem reasonable. Still seems blurry:)
    PRI Get_Acceleration_Data
          accxi:=i2c.readByte(BNO055,LIA_DATA_x_MSB)
          accxi:=accxi<<8
          mydata:= i2c.readByte(BNO055,LIA_DATA_x_LSB)
          accxi:=accxi+mydata
          mydata:=accxi
          tester:=1
          mydata:=mydata<<17
          mydata:=mydata>>17
          if mydata<accxi
             accxi:=1+ not(accxi)
             tester:=-1
          accx :=tester*accxi
  • The ">>" operator is an unsigned shift. You should use "~>" to do a signed shift. So your "mydata:=mydata>>17" should be "mydata:=mydata>>17". Or you could write it as "mydata ~>>= 17".
    The shift by 17 assumes that the data is only 15 bits. If you really have 16 bits of data you could shift by 16, or you could use the "~~" sign extension operator.
    Took a nap... things always look better after a nice little nap.
    Thanks guys
    edited 2016-01-08 06:15
    If the two-byte value is a signed word, you could do this:
    pri get_accel_x_data | tacc
      tacc := i2c.readbyte(BNO055, LIA_DATA_X_MSB) << 8
      tacc |= i2c.readbyte(BNO055, LIA_DATA_X_LSB)
      return ~~tacc
    hmmm.... and just when things seemed so clear:)
    I'll tell you what though, even with my miserable programming... this little package is looking just fine:)
    I'm going to look at this again in the AM
  • gis667en11gis667en11 Posts: 73
    edited 2016-01-08 14:56
    JonnyMac wrote: »
    gis667en11 wrote: »
    Oh. Duh. The cogs all use longs for everything, so of course it'd have to be signed to a long. Thanks JM
  • Would you mind posting the code you're using to interface to the sensor? I've been having difficulty with getting any data out of mine at all.
