mixing rfbyte and rfword
in Propeller 2
Using a well tested serial routine (on the Prop2 side)
connected to a somewhat flakey serial connection on the computer side...
to read from the computer into the P2 and interleave image and distance data
(from a KinectV2). The image data is a byte and the distance data is two bytes.
Once I call this, the P2 doesn't seem to respond to further commands although the
computer side of things seems fine.
I suspect that mixing wfbyte and wfword might not be allow?
kinect2hub mov z,##230400 mov ptra,##_Off_SCREEN_BUFFER wrfast ##0,ptra .get3bytes call #rcv_char wfbyte rx_char call #rcv_char mov xx,rx_char shl xx,#8 call #rcv_char add xx,rx_char wfword xx djnz z,#.get3bytes mov rx_char,#0 ret
The total buffer is 230400 bytes... but I am grabbing 3 bytes per loop... so I only need to
loop 76800 times. With this fix... all is well. Sorry.
By the way... the P2 is just fabulous.
