midi from stamp — Parallax Forums
midi from stamp
Can any of the stamps output midi messages ?
Simply the right speed serial out (no opto needed)
To drive one of these :
https://www.sparkfun.com/products/10587
  • The stock BS2 can do it -- you just have to calculate the correct baud constant for 31250. As that shield plugs into an Arduino, I'm guessing that true mode coms is what that board is looking for.
    Here's an article I wrote (yes, I am the artist formerly known as Jon Williams) about sending MIDI messages from a BS2:
    -- http://peabody.sapp.org/class/dmp2/read/nv94_gettin_midi_with_it.pdf
  • Thank You !
    Actually this is the one I will use :
    https://www.adafruit.com/products/1381
    I've used both a PicAxe and MicroMite with the SparkFun
    and FluxamaSynth synths, but thought I'd try something
    (slightly) new ...............
  • If you want new, you should go with the Propeller! It's very powerful, yet easy to program.
  • JonnyMac wrote: »
    I'm afraid I'm 'challenged' when it comes to anything other than Basic.
    I have thought about the MicroMite/Propeller hybrid out there with
    the Atari emulator (can't remember the name now)
  • Trust me, if an unknown (for now!) actor from Los Angeles can master the Propeller, so can you -- if you get out of your own way and just get on with it. Trust me, you will have a lot of fun once you dip your toes into the waters of multi-core programming!
  • Spin ?
  • hitsware,
    I was intimidated by Spin at first but it's very similar to PBASIC though a few commands work differently.
    I learned Spin from the Propeller Education Kit text and looking at other people's programs and projects.
    https://www.parallax.com/sites/default/files/downloads/122-32305-PE-Kit-Labs-Fundamentals-Text-v1.2.pdf
    There is also a short tutorial in the old V1.01 Propeller Manual.
    http://www.rayslogic.com/propeller/Propeller Manual v1.01bmarked.pdf
    The Propeller Activity Board is the best value and it happens to be on sale now.
    https://www.parallax.com/product/32910
  • How does the 'C' programming relate to 'Spin' ?
  • hitsware wrote: »
    You can program the propeller chip with various tool chains. One is Spin and PASM, the 'nature' languages, develop by the chip designer himself. Then there are multiple C compilers, one based on GCC. You also can use PropBasic or FORTH and multiple other variations and languages.
    Someone even wrote a program to run ladder logic on the prop. can't find it anymore.
    but Spin is quite easy to understand if you are used to basic.
    Enjoy!
  • Spin is very easy to learn and is directly connected to the architecture of the Propeller. Once you're very comfortable with that, moving to other languages is a bit easier I think. Spin and C are not very far apart; I frequently port interesting bits of C code to Spin, and many people have gone the other direction, too.
  • Does Spin (or any of these other languages) have a SOUND or FREQOUT or TONE
    or PWM or somesuch command ?
    What Spin documentation I've found is (for me) pretty much useless.
    Note ! " for me " ...... I'm not knocking it .........
  • JonnyMacJonnyMac Posts: 9,554
    edited 2015-12-18 23:42
    No, but they're easy to add. In fact, if sound and music is your deal, there are sound chip emulators (like SID) available for the Propeller. Here's a demo on YouTube:
    https://youtu.be/Qlfsr-9_FBY
    There are other sound systems, too, especially from those into retro gaming. At EFX-TEK (myself and another former Parallax employee) we created a commercial WAV player board from the Propeller that gets used in museums, trade show displays, movie props, and amusement parks (including a very famous one here in SoCal I'm not allowed to mention).
    The Propeller doesn't have a lot of "fancy." What it does have is the architecture to let YOU be as fancy as you like.
    My acting coach, the late, great Cliff Osmond, used to say, "You can do this -- you just have to get out of your own way." I promise that if you'll get an Activity Board and give yourself 30 minutes a day for a month (yes, the first few days will be tricky), you'll get it and then start kicking yourself for not trying the Propeller sooner.
    There may not be as much hold-your-hand documentation for the Propeller, but what's there is valid. And you have these forums where many of use will -- if you'll put in a bit of effort -- help you work through the tricky stuff.
  • hitsware wrote: »
    You're in luck! Martin Hebel, ( a good forum member) wrote some BS2 functions for the Propeller:
    http://obex.parallax.com/object/164
    You might look around the OBEX for some great objects for the taking.
  • JonnyMac wrote: »
    One of my favorite approaches .....
    BBC BASIC (the only contemporary BASIC with SOUND)
    for WINDOWS (which comes with a software midi synth)
    no midi here :
