Connection bs2pe with lcd backlit #27977
in BASIC Stamp
hi everyone
I am beginner micro-controller world. I want to ask, how to connect RX pin of LCD to Daughter A at Bs2pe board? For your information, Daughter B, I connect with color sensor #28302 and it's work.. Thank you.
In the meantime you can have a look at these sample programs to get a feel for the programming interface.
https://www.parallax.com/product/28300
I can't put my hands on the board right now. I also have a daughter board which also MIA.
The TC3200 Color Sensor Product Document on page 3 shows that it uses P7 of socket B for Serial I/O communication, which the BASIC Stamp 2pe Motherboard Documentation on page 4 shows is not pulled up.
https://www.parallax.com/sites/default/files/downloads/28302-TCS3200-doc.pdf
https://www.parallax.com/sites/default/files/downloads/28300-BS2pe-MoBo-Documentation.pdf
P11 and P12 of Socket A are also not pulled up, but the schematic on page 5 shows the GND, P11, and +5V pins are all on the same side of the connector; The same 3 pins that the Parallax Serial LCD Product Guide shows are needed by the LCD.
https://www.parallax.com/sites/default/files/downloads/27979-Parallax-Serial-LCDs-Product-Guide-v3.1.pdf
Looking at the photo of the BS2pe Motherboard I see that GND is top pin next to the Jumper, P11 is the 3rd pin up from the bottom, and +5V is the bottom pin.
