Multiple Propellers loading from one eeprom
cbmeeks
in Propeller 1
I searched but couldn't find what I was looking for. Perhaps my search terms weren't that great.
Anyway, I was thinking about a circuit that has 2 to maybe 4 propellers. One propeller would be connected to an EEPROM as usual but when it booted, it would then copy 32K chunks to the other Propellers. Next, all of them would somehow get in sync.
Perfect sync wouldn't be a huge concern. But maybe something within a few microseconds. For example, one propeller for audio, one for video and one for I/O. All synced by maybe the NTSC refresh rate. Hope that makes sense.
So, is something like that feasible or would it just be easier (better) to put an EEPROM on each one and call it done? Those things are microscopic anyway. lol
Thanks!
Thanks!
These days, I'd just put a 64K (24LC512) EEPROM on each Propeller and be done with it.
You really don't need much at all. :-)
If I go simple and frugal in my design, I will only have one Propeller. If I go overboard and crazy, I may have three. So three EEPROMS it is. LOL
Thanks.
I use a different aproach than Mike suggests. Both Propellers share the SCL and SDA lines. The master propeller holds the reset signal of the slave low until it has booted and started up, then it releases reset and the second propeller begins to boot. You don't need special software to boot the second chip, just one pin for the reset signal. If you pull this pin low at the slave you can also use it for the software to know in which chip it runs. This is useful if both propellers use almost but not exactly the same code.
