My Propeller talks kind of QBUS and yours ? — Parallax Forums
I got fascinated with the russian produced pdp-11 clones, like the KR1801VMx. There are a number of sources for documentation, mostly in russian. Another world completely. I decided to try to build a BK-0010 or similar.
This processor has a QBUS interface, directly on die, meaning it does not have separated address/data and normal control lines. Some of the control lines are open-collector and some totem-pole. Of course, you can look at the recently captured schematic of the A or G versions, and peek at the verilog of a (quite) accurate replica for better understanding but hooking the processor to our propeller provides, I think, the ultimate level of gratification (if it works) :).
It kind of works, I'd say. The address/data bus is inverted (to confuse the unwise :))... I send 0xEFFE what I think should be mov r0,r1. Why do I like the pdp-11 so much ? No idea, maybe because I also like its direct descendant, the 68k...
I ordered one of this processor from ebay, it seems to work, and yeah the clock is 10 MHz there, that seems to work, I lowered to 5 and it started to not start correctly.
QBUS to Propeller
        Connection Diagram
        │      P30├─── Propeller's TX line
        │      P31├─── Propeller's RX line
        │      P23├─── DOUT   Write
        │      P22├─── ACLO   Assert to reset
        │      P21├─── DIN    Read
        │      P20├─── WTST   Sample on falling edge
        │      P19├─── SYNC   Latch negated address on falling edge
        │      P18├─── RPLY   Assert on Data on Bus for Reads or Writes
        │      P17├─── INIT   Assert to reset peripherals
        │      P16├─── Clock 5 MHz
         Propeller
            MCU
          (P8X32A)
Memory Map:
$1000..$2000
Components:
N/A
CON
  'Set up the clock mode
  _clkmode = xtal1 + pll16x
  _xinfreq = 5_000_000
  '5 MHz clock * 16x PLL = 80 MHz system clock speed
VAR
  'Globally accessible variables
  long rom[2048]
OBJ
  'in leiu of Parallax Serial Terminal, FullDuplexSerial is being used to communicate with the terminal
  serial        : "FullDuplexSerial"
PUB Main
  Starts execution of FullDuplexSerialTest1.spin
  This is a very simple test.  It starts the object, waits 1 second, prints two
  lines to the terminal, waits 1 more second, then shuts down.  Set your terminal
  to a baud rate of 9600 baud to see the output.
  parameters:    none
  return:        none
  example usage: N/A - executes on startup
  'start the FullDuplexSerial object
  serial.Start(31, 30, %0000, 115_200)                    'requires 1 cog for operation
  waitcnt(cnt + (10 * clkfreq))                          'wait 1 second for the serial object to start
  serial.Str(STRING("Pacito's QBUS Interface Ready."))     'print a test string
  serial.Tx($0D)                                                 'print a new line
  cognew(@qbusm, @rom)
  serial.Str(STRING("All Done!"))
  waitcnt(cnt + (1 * clkfreq))                          'wait 1 second for the serial object to finish printing
  serial.Stop                                           'Stop the object
CON
P_DOUT = 23
P_ACLO = 22
P_DIN  = 21
P_WTBT = 20
P_SYNC = 19
P_RPLY = 18
P_INIT = 17
P_CLK  = 16
DAT
              org
qbusm         mov       tstartrom, PAR
              mov       CTRA, C_CTRA
              mov       FRQA, C_FRQA ' generate 4 MHz clock
' force RESET, ACLO and INIT low for 40 ms or so
              mov       DIRA, C_DIRA_RESET
              mov       OUTA, #0                ' not really needed...
              mov       tcnt, CNT
              add       tcnt, C_40MS
              ' de-assert periph-reset and later power fail
              waitcnt   tcnt, C_70MS
              or        OUTA, C_INIT
              waitcnt   tcnt, #1
              or        OUTA, C_ACLO
qbus_wait
              mov       taddr, C_FFFF
              waitpne   C_SYNC, C_SYNC
              xor       taddr, INA              ' get normal address and wtst
              waitpne   C_DIO, C_DIO            ' wait for DIN or DON being asserted
              ' if read
              ' assume read
              xor       OUTA, C_NOP
              or        DIRA, C_FFFF_RPLY       ' asserts RPLY
              waitpeq   C_DIN, C_DIN            ' wait till DIN is negated
              andn      DIRA, C_RPLY            ' negate RPLY
              andn      DIRA, C_FFFF_RPLY       ' set as inputs
              waitpeq   C_SYNC, C_SYNC          ' wait for SYNC to be negated
qbus_e        jmp       #qbus_wait
tcnt          long      0
taddr         long      0
twdata        long      0
trdata        long      0
tstartrom     long      0
C_NOP         long      %1110_111_111_111_110 ' MOV R0, R1 '%0001_000_000_000_001 ' MOV R0, R1
C_FFFF        long      $ffff
C_FFFF_RPLY   long      $ffff | (1 << P_RPLY)
C_CTRA        long      %0_00010_011_00000000_000000_000_010000
C_FRQA        long      $10000000
' All inputs except ACLO, INIT, CLK
C_DIRA_RESET  long      (1<<P_CLK)|(1<<P_ACLO)|(1<<P_INIT)
C_INIT        long      1<<P_INIT
C_ACLO        long      1<<P_ACLO
C_RPLY        long      1<<P_RPLY
C_SYNC        long      1<<P_SYNC
C_DIO         long      (1<<P_DIN)|(1<<P_DOUT)
C_DIN         long      1<<P_DIN
C_DOUT        long      1<<P_DOUT
C_WTST        long      1<<P_WTBT
C_40MS        long      (80_000_000 / 40_000)
C_70MS        long      (80_000_000 / 70_000)
1073 x 232 - 13K
1195 x 672 - 41K
    That has to be one of the most exotic projects I have ever seen around here.
    What a neat bus interface.
    Any pictures of this thing ?
  • Freakin' awesome!!! I love this place!! Way to go Ale!!!
    Pictures?
    Old Computer Museum
  • AleAle Posts: 2,363
    Pictures or it didn't happen :)
    1024 x 683 - 317K
    edited 2016-12-04 09:15
    One year is gone, and I remembered that this board didn't work as I thought.
    Of course there is quite a bit of information about these processors, and HDL models too, and schematics. But mostly is in russian, and not even in electronic readable form :(. Yeah, scans of type-written and hand-written docs. It took a lot of thinking and a bit of testing, now it really works.
    What I mean is:
    AD Bus is wired-or and pulled-high and uses negated logic, that's why you see FFFFs.
    *RPLY has to be asserted (low) for every access that is not an internal access. It is wired-or, needs a pull-up (I'm using 453 R to a 3.3 V rail :). It cannot be grounded like the DTACK on the 68 K !!!, the processor does not come out of reset, nor can it be grounded after reset.
    The code I used didn't work as expected, I improved it a bit, now it asserts *RPLY correctly and sends a NOP.
    The first access is to an internal register with internal generation of *RPLY to get the high bits of the initial PC, which happens to be zero, then it executes NOPs (what I'm feeding).
    Now, let's see if I can convert this into a BK-0010 or similar.
    The manual of the KR1801VM1 claims something like 1.7 MIPS: but it takes 11 clocks to fetch the next NOP... meaning less than 0.5 MIPS. A slight over-clock to 6 MHz didn't work, I couldn't catch the assertion of DIN. Maybe just waiting 2 instructions is enough to decide if is a read or write instruction. Read-modify-write instructions exist, they seem to keep *SYNC asserted, and they assert first *DIN and after negation of *DIN *DOUT is asserted. The small code I wrote do not recognized them. The propeller should only provide a video interface, so I will write in parallel to RAM and HUB memory, so I think it would not be necessary to acknowledge such cycles with the propeller. I could dedicate a cog just for that.
    The PLAN :)
    2 RAMS for 16 bit bus, 2 FLASH ROMs and the propeller as video controller, it should work, I think
    1478 x 264 - 20K
  • Ale,
    How is your 1801 project going?
    I bought some KM1801BM2 parts on ebay. Like yours but different. I started using a Prop but I needed more I/O, so I made a board with a dsPIC33, 2 32Kx8 SRAMs, and 2 HCT563 latches. The PIC runs at 140 MHz at 5V, so there are no interfacing issues. It also generates the 2X CPU clock for the 1801. The PIC uses DMA to modify the battery-backed RAM contents. It also implements a console, GPIO, etc. for the 1801.
    I am still trying to understand the behavior of the 1801BM2. I can't find a proper data sheet anywhere, and I don't speak Russian!
