Expected read speed for a 512 block on micro SD with SPI?
Hi everyone,
I couldn't find this information anywhere and my SD card module is in the mail; I was curious enough that I decided to ask. What do you think I could expect in terms of read operation baud rate to get 512 bytes, or 1 block, from a class 10 micro SD card? I'll certainly be conducting my own experiments over the weekend, but if someone else has had done a time sensitive project with an SD card over SPI, I'd love to hear what your experience was with reading fast?
Kye's Fat_Engine is more comfortable and FSRW is faster.
Both provide a whole FAT System, so are a bit slower as if just reading/writing Sectors.
The PASM block-driver out of FSRW is IMHO the fastest way to access Sectors. It provides read ahead and write behind function.
The result is that your main cog does not have to wait long for writing a sector, and if you -say - read sector 34, sector 35 will be read ahead and is available very fast.
Overall you can get speeds between 800 to 1200 Kbytes per second.
Enjoy!
The numbers @msrobots gave above are about right. They're so much higher than my own I had to go find a source for them, which I did: http://forums.parallax.com/discussion/136781/fsrw-2-6-speed-tests
In my own implementation (C++) is much slower since I did not implement look-ahead or write-behind. I only benchmarked the equavalent of FSRW's pputc and pgetc, but I get about 13.3 kB/s in LMM and 3.7 kB/s in CMM.
It's not necessary to store all the data in ram, only to to read it in, so only a small amount of ram is required. Possibly as little as a single byte depending on how the code is written.
That's exactly it. I can't speak for FSRW's benchmark, but PropWare's "benchmark" is pretty basic:
This will do a byte-by-byte copy from the read buffer to the write buffer. As the read buffer (512 bytes) reaches the end, it overwrites it with a new one and as the write buffer (also 512 bytes) reaches the end it writes it to the SD card and overwrites it too. This means that you only need 1024 bytes of memory for buffers, not the full file size.
SD card can only be read from and written to in 512 byte chucks, so the chip must keep at least a 512 byte buffer for reading and writing.
If at any point you decide you like FSRW but want to give C/C++ a try, libpropeller has ported FSRW over to C++, so you can get the same feature set and performance in a completely different environment. I don't know much about PropForth and Tachyon, but I know they each support SD cards as well and are very fast and efficient.
I'm not sure who convinced you that programming in C is slower than Spin, but that isn't the case. There are ways to make C slower than Spin, and there are ways to make Spin slower than C.
If you think you'll have it all in assembly anyway, then I definitely suggest starting with C/C++ because you write only the functions you need in assembly (inline assembly) and then slowly convert more and more into assembly as performance demands. When the inline assembly becomes too unweildly, you use a .S file the same way you would the DAT section of a .spin file.
Ahhh, now I understand haha. I read in a few places, and heard from a Propeller technical support representative, that spin was faster. What do you mean when the "inline assembly becomes too unweildly"? What is "inline assembly"?
Scratch that- I googled it. Seems complicated, but powerful. I wonder, why not just use a propeller C to PASM compiler?
That's exactly what a C compiler is.
It takes your C or C++ code and creates assembly instructions for it. If you add the "-s" flag when compiling (such as "gcc -s main.c") you'll get an extra file such as main.s. That main.s file is the assembly generated from main.c. Now, if you're using CMM memory model, then it's a little different (see the ongoing disucssion here: http://forums.parallax.com/discussion/163002/simpleide-c-output-tokens-or-native#latest) but basically the same.
The reason you might use inline assembly is because the compiler is omnicient. It's REALLY smart, but every now and again, a human is able to write better code than a compiler (especially with a CPU that isn't RISC-based, like the Propeller). So, for those cases we can tell the compiler exactly what assembly to write, instead of allowing it to make an educated guess.
I wrote Tachyon so I could use it in my commercial products, and so it just has to work. Tachyon is very fast at the high-level plus it treats the SD card and files as virtual memory, even at the FAT32 level. To open a file and print out a 32-bit number at position 2000 in a file is as easy as typing into the console:
FOPEN MYFILE.TXT
2000 F@ PRINT
- or to dump the whole file to the screen -
0 FSIZE@ DUMP
The latest update to Tachyon which I am backporting from the P2 version supports virtual memory access from within files as well as the original access from the first 4GB of the card, so files up to 4GB can be accessed as if they were memory. Up to 4 files can be opened at a time plus Tachyon doesn't require a dedicated cog just for SPI or SD card access. Networking and VGA etc are also built-in, all in the standard unexpanded Prop.
EDIT: just found a post where I stated that I get "sustained" read speeds of 250kB/second running out of the same cog as the Tachyon kernel and application.
I have a project where I need to be madly logging data to the card from a network of over 40 Props up to 240 times a second!
Just a guess, but if he needs 40 of them, each with 8 cores, it sounds to me like he needs some serious parallelism!
1) Longevity of the selected device.
2) No need to comprehend 4000 page manuals to get the the thing working.
3) Code running on separate cores makes things predictable and reliable. Especially timing wise. Google "Communicating Sequential Processes".
4) Code running on separate cores means that changes to one part are easy, you know that they cannot upset other parts.
5) Lots of support, easily available, like this very forum.
That, and Forth really excels at these kinds of things. I only know a few Forth guru types, they all pretty much echo the sentiments Peter does here. The amazing thing to me is what can be done quickly, once a working kernel is bootstrapped on to some machine.
@Peter, thanks. You shared a lot. It is not my thing, but I have learned a lot from your efforts. Honestly, I see the Forth mindset as a significant barrier. It is for me. However, for those who grok it, you have left pure gold here.
However, I am surprised by the talk about Forth specifically instead of Tachyon. For instance, Peter gave the following examples:
One could just as easily have a C/C++ interface that looked like:
What I see that's magical is that Peter went through the work to create the functions that do this, not that the Forth language supports the ability to do it. Am I missing something?
Part of that mindset I suppose is that of simplicity. Take the the PRINT function in Forth (normally "."), all it does is take a 32-bit number off the top of the stack and print it in the currently selected base. So essentially it is THE subroutine whereas in C "print" is far from that as first it is more of a compiler directive really. We are asking the compiler to generate the correct sequence of operation and calls based on the syntax so there is a whole heap of stuff that has to be done on the PC at compile time whereas Forth has none of that, it normally "assembles" as I like to say on the target device itself without regard to syntax and all we get is the equivalent of a call to that PRINT subroutine. Simple!
Forth is not the answer for everything, but it does work very well for chips at this level. A small PIC I would just code in assembler, an RPi has plenty of language support, but at that level you are compiling and testing directly on the target, just as I do now with Forth on the Prop.
@gis - just like Heater said. I don't need the pain and grief wrangling with these little fellas with their inversely (dis)proportional levels of documentation and tools. Besides you may have gleaned from my description that each Prop has 4 network buses plus the console serial port running, something that is very easy to do with the Prop besides many other things.
You have blown my mind there.
Assuming we are talking C here: Leaves us with a handle/pointer thing "f" for a file.
I have no idea what "print" does but it seems to me that printing file handles is pretty dull.
I am amazed at what Peter can do with the Tachyon. He is living in a twilight zone of his own creation. Which seems to be profitable for him. More power to his elbow. Dare we enter there? It's not for me.
I'm more referring to C++, so perhaps that clears up some confusion.
I only wrote it like that as an example that it could be done. In practice, I'd write a function with the signature: "PropWare::Printer& operator<< (FILE *file)". Then if someone really wanted the syntax above, the function would be as simple as:
Or rather than the FILE pointer from the C world, I'd use PropWare's FileReader class.
There's another Forth word (FOPEN$) that takes a pointer to a filename and opens it. FOPEN is intended for either interactive use or in compiled code where the filename is fixed.
