Yet another I2C driver - with utilities
Erlend
in Propeller 1
Just had to make my own driver, bit-banging the protocol into my brain so that it sticks. Includes some utilities for scanning and re-addressing.
But why does it not show up when I do a Search on OBEX?
Erlend
Erlend
http://obex.parallax.com/object/832
http://obex.parallax.com/object/830
I just sorted by posting date, and they all showed up.
Sounds cool.
When posting a summary, you could include the Clock range supported, and if it is master, or slave, or both, and if it supports Clock Stretching.
Erlend
To check the speed of a master, you can capture time before/after some common sequence like Read 1 or 2 bytes from Serial EEPROM.
Repeat with differing pull-ups.
A pull-up of 1k is only 3.3mA of BUS current.
