Resource for proven/rugged uController interface circuitry?
Mickster
The internet is awash with all kinds of hobby-standard interfacing ideas but I wonder if a resource exists for designs where component cost is not an issue. I am looking for rugged and reliable solutions.
Hobbists solutions can be better spec'ed and built than some commercial, off the shelf, built down to a price equipment.
'rugged' against what ?
We had one product under aggressive ESD testing, and that was not so much any interface that needed attention, but more providing a pathway for the ESD current to avoid anything sensitive.
Or, if you are worried about EMC testing, ferrite beads are often added.
I recall one story of an Engineer at Philips using a bare wire + metalworking file(!) as a Noisy-mains-contact stress tests on SMPS soft start.
We've also used a 'chattering mains relay wand', as a watchdog recovery test. Quite revealing, and proved on many parts 'reset'; is more like a 'reset request' and showed why power-removal-watchdogs are often the best.
I guess it's mostly analog inputs that I'm referring to. For digital I/O, I already have opto-couplers, line-receivers, SSR's, etc. but for analog inputs, I just go with an op-amp and that's it?
I guess the reason for the question was just in case there was a Great Book of Best Practices out there
@Beau: The last time I touched a PLC was a Gould Modicon back in 1981. Somehow I have spent the last 30+ years working with machine tools and factory automation without touching another PLC.
I did take great pleasure in kicking AB's butt in 1988 when they (a whole bunch of engineers) attempted to do with a SLC-500 what I was doing with an office grade PC+motion card+OPTO22-AC5. They failed miserably.
Some opamps have sensitive inputs with limited swing tolerance, those may need additional clamps - better ones will spec ESD & RFI levels.
Yeah, I prefer this. I might just convert every external 0-10v that I come across to 4-20mA.
See the datasheet on this item... There are cheaper Opto's but the datasheet on this particular one has lots of application examples.
http://www.digikey.com/product-detail/en/HCNR200-000E/516-1522-5-ND/696022
rugged-circuits.com/10-ways-to-destroy-an-arduino
@RickB: Many thanks also. I came across one of their sample circuits last week but at their site, could find nothing but (VERY nice) product. These are the sort of design precautions that I am interested in.
