Help with coding
in Propeller 1
i am having trouble getting a countdown timer to work. It is counting down however will not display the countdown itself.
the dispenser running with time is my work. the code is the project I was using it from the timer four comes for the timer plus countdown code.
any help to fix this is appreciated.
thanks
thanks
My timer object accumulates the time between accesses using the cnt register, so it's best to call it as frequently as you can. I recently used this technique on a jump controller trainer for Army paratroopers.
