Is there a formal specification for Propeller assembly? — Parallax Forums
Is there a formal specification for Propeller assembly (not Spint)?
I found a BNF in the Machine Language Tutorial by deSilva and a Parser [1], none of which seem to be official.
Is there something approved by Parallax?
[1] https://github.com/ZiCog/pasm.js
    No. Not in terms of a BNF spec. As far as I know the Propeller manual is as close as you get officially.
    Not sure you can say "excluding Spin" exactly as PASM depends on a lot of the expression syntax of Spin for DAT, VAR definitions.
    edited 2015-12-05 17:00
    Be sure to get the Propeller Manual v1.2 which is only an on-line download (free) - never been published in book form. It has quite a bit of important revision.
  • Thanks, Header. and Loopy Byteloose.
