Looking for a very simplified VGA example.
handermanntr
in Propeller 1
Hello,
I have been attempting to get a simple VGA single screen color driver working in asm, and I can't seem to get it to work. I have been trying to do it by modifying existing drivers, but they are all to complicated for me to modify to do this simple thing. i am wondering if anyone can supply a completely stripped down driver(IE. everything statically set for an 80MHz clock, any resolution, single color screen, minimal settings). Basically, I am wanting to learn how it works, but they existing ones are too complicated from all the different settings.
Also, if you cant supply this, maybe someone can answer these questions:
1. Do you have to provide a specific clock via CTRA, or will any reasonable clock work(IE, can I clock it at 80MHz, or does it have to be specific for a format), and if it does have to be specific, can someone supply a table of these?
2. Can someone supply an equation that I can use to calculate FRQA to generate a specific frequency with PLLA internal(Ignore PLLDIV, say it is just VCO/16/equal to the input clock)
3. How exactly are the Vsync and hsync signals generated via code?
4. If during the active video pixel clocks I use waitvid with $0000_FC00 for colors, and $FFFF_FFFF for pixels, should this display a full white screen?
Thanks!
Thanks!
http://forums.parallax.com/discussion/134552/barebone-vga-driver
- You need to calculate FRQA to give the desired pixel clock
- See AN001 Propeller P8X23A Counters
- For VGA, HSYNC & VSYNC are simply periods with the HSYNC & VSYNC bits in the output byte set or cleared to generate the appropriate signals. The Propeller Video Generator doesn't know anything about HSYNC / VSYNC, you just set the VSCL to generate the appropriate number of pixel clocks, and WAITVID the right bits.
