How does PLL generate 80 MHz from a 5 MHz crystal?
cbmeeks
in Propeller 1
I've read the Wikipedia article but it just isn't sinking in.
And I get that 5 * 16 = 80 but how does the PLL circuitry actually produce a signal that is 16 times its input?
Thanks!
Thanks!
It's trying to match its own voltage/phase but as its output goes through a /16 divider it will create a signal that is 16x as what it's trying to match.
As Kwinn have said.
The answer is not on the "PLL" page, the answer is on the "Frequency multiplier" page.
It is the VCO that is already running at around 80 MHz, and the PLL just only compares both clock phases and apply "voltage" feedback.
