Digital I / O Board
                                  in Accessories
                    Is it possible to connect the i/o board directly to a rs232 on a Panel PC? Any code or HW exampels arround?  I'm a beginner on electronics and need a simple way to control some Inputs and putputs.
You would do better with some of the boards from EFX-TEK, a Prop-2 with a couple of I/O Amigos if you need relays for controlling AC power. The Prop-2 can be used with the Digital I/O Board Kit as well and plugs into an RS232 port for either programming or control. There are plenty of code examples, both from Parallax and EFX-TEK. The Prop-2 can directly control small DC loads on the order of 12V and 1A and can handle DC inputs up to 5V. If you want to control AC or sense AC, you'll need a relay for control or an optoisolator for sensing like what's on the Digital I/O Board.
You could also get a Parallax Stamp Board of Education for use with the Digital I/O Board. The Prop-2 is an equivalent specifically designed for controlling small DC loads and sensing switch closures and other 5V signals.
