How do you read nrf24L01 registers?
lardom
in Accessories
I tried to write a simple test to see if I was writing to an internal register of the nrf24l01+ module. Arduino users have a large library but it's not common among Propeller users. I'm hoping I don't 'have' to learn to read Arduino code.
The test returns '0'. I should get '$02'.
CON 'test reading internal registers nrf24L01
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
'Pins
SPI_SCK = 5
SPI_MISO = 7
SPI_MOSI = 6
SPI_CSN = 4
SPI_CE = 3
OBJ
SER : "FullDuplexSerialPlus"
VAR
long mystery_var, talk_back
PUB Configure_TX
SER.start(31, 30, 0, 57600)
waitcnt(clkfreq * 2 + cnt)
dira[SPI_MOSI]~~ 'master out slave in
dira[SPI_MISO]~ 'master in slave out
dira[SPI_SCK]~~ 'serial clock
dira[SPI_CSN]~~ 'chip select NOT
dira[SPI_CE]~~ 'chip enable
outa[SPI_SCK]~
outa[SPI_CSN]~~
SPI_Write($20) 'write to config register $00
SPI_Write($02) 'power up PTX
SPI_Write($00) 'read config register command
Read_Register 'looking for return data
PRI SPI_Write(n) | idx 'mode 0
'I want to read data in register $00
talk_back~
outa[SPI_CSN]~
repeat idx from 7 to 0 'MSB 1st
outa[SPI_SCK]~~
outa[SPI_MOSI] := n >> (idx)
talk_back += outa[SPI_MOSI] << (idx)
mystery_var += outa[SPI_MISO] << (idx)
outa[SPI_SCK]~
outa[SPI_CSN]~~
SER.bin(talk_back, 8)
SER.tx(SER#CR)
SER.bin(mystery_var, 9)
SER.tx(SER#CR)
PRI Read_Register | idx
repeat 2
outa[SPI_CSN]~
outa[SPI_SCK]~~
' talk_back += outa[SPI_MOSI] << (idx)
outa[SPI_SCK]~
outa[SPI_CSN]~~
SER.bin(mystery_var, 12)
SER.tx(SER#CR)
