Step 37 Synchronization and Range check
Good morning all, I am at step (37) Synchronization and Range check, I can not get the transmitter and ESC's to synchronize, the Hoverfly Open flashes purple and the ESC's beep. The receivers LED is a solid orange. I have followed all the steps in Parallax ELEV8 manual. I am using a Spektrum DX7 transmitter, Ar8000 receiver. The FC never blinks green. If anyone could help I would greatly appreciate it tremendously. Thank you for your time!
T.W.
T.W.
Do you have a quick picture of your setup?
Check to see if Chan 5 is reversed or not. Gain is set to 25%.
I'm sorry you are having issues with your ELEV-8 v2. Have you contacted (call or e-mail) our tech support about the issue yet? There are here to help you, so I strongly encourage you to get in touch with them. They won't rest until the issue has been fixed; it's one of the things that makes Parallax so unique! I've already briefed them on your situation.
The beeping and flashing purple indicates the ESC is in Trouble mode - which is activated when one of the 5 required receiver channels is not detected. Of course, from your photos I can tell that you have the receiver cables plugged into the flight controller correctly (though I can't quite visually confirm that they are in the correct order and are connected to the receiver correctly). If all of that is confirmed to be correct, as well as transmitter settings, then this is an unusual situation, and there could something else amiss - (such as a defective flight controller, but that is very unlikely)
If you PM me an e-mail address, I can send you my DX7 settings file for my ELEV-8 v2 (you'll have to re-bind and have all switches in the 0 position).
Again, I strongly recommend contacting our tech support!
Let use know how you did.
Hang in there. Kyle knows that transmitter better than me.
As I told Tom on the phone, from the pictures; it seems that the wires connecting the receiver and the Hoverfly Open board are plugged in backwards to the receiver. It shows from the picture that the signal is the top wire, where it should be the ground wire (as shown in the picture below).
I got an email from Tom, with links to videos he made of his ELEV8 successfully running after fixing the wiring (yay!)
Respectfully
Zakia Ben Youss
Technical Support
Parallax, inc
Here is a couple of videos for the test start-up of the ELEV8v2 and maiden flight.
Thanks everyone for the help.
