Laboratory multi channel peristaltic pump controller
DarrylBorland
Hi I`m new to Parallax forums so here goes.
I have some old laboratory grade peristaltic pumps that I wish to convert to computer control. Basically I need to drive the pump motor forward, backward and stop and vary the speed. I was thinking of using the HB-25 controller #29144. But would like to use USB to talk to the microcontroller.
Any ideas or direction would be great.
Darryl
Darryl
Welcome to the forum. Some info about the pumps would be useful, like what voltage do they require and how much current do they draw. The HB25 may be an expensive way to go.
Jim
As far as using a USB interface, a Propeller board can provide you with that. And Forth on the Propeller would interactively help you to quickly dial in whatever you desire those pumps to do. With the Propeller, it would be easy to have multiple pumps responding to independent pump cycles.
Is that 220 volts DC?
Thanks again,
Darryl
Since you want to drive forward, backward, stop, start, and vary speed; all the specifics of the motors are extremely important. And you may find that the motors you have won't reverse or vary speed. AC motors will require a very different solution than DC motors, and there are various types of AC motors.
If that is the case, you may have to consider a change over to a different set of motors. You might also require quadriture encoder sensors attached to the motors for precise feedback to allow PID motor control.
Do you have any ballpark power rating on these motors such at 1/10th HP, 1/4 HP or such?
Given 'a few amps at 220V' where amps times volts equals watts, you seem to have something like a 500 watt motor. With 745 watts per horsepower, you are indicating 2/3 HP motors or larger.
There may be an industrial servo controller that is already well suited for these devices. Whatever you do decide to use, should have a proven performance record for such large motors. I fear it won't be cheap.
