Easy Bluetooth RBT-001 don't Leaving transparent mode
Hi all,
I've successfully connected with RBT 001 then I transfer package SET_EVENT_FILTER
0x02, 0x52 , 0x4E, 0x01, 0x00, 0xA1, 0x03, 0x03
EventFilter: Configures the level of events reported to the host.
0x00: No filter, all events reported
0x01: ACL events filtered, only API events reported
0x02: All events filtered, only UART breaks indicated
0x03: All events filtered, including UART break
I've put the value 0x03 for SET_EVENT_FILTER then it works in transparent mode. I use Uart break (TX go GND) tried to go back Command Mode but can not. How do I get back Command Mode?
Thanks in advance !
Thanks in advance !
Welcome to the forums!
Do you have any more detail on the microcontroller (or control board) you are using, and how you have that hooked up to the RBT-001 ?
