Simple Action-cam base for ELEV8-V2
Hi everybody,
Here is a very simple cheap and very reriable solution in order to cary an Action cam with your ELEV8.
Is a 3d printable base for cameras with dimensions: (5,9cmX2,4cmX4,4cm)
You can find the base on Thingiverse : http://www.thingiverse.com/thing:1135756
You can also modify easyly the 2nd part of the base, according your camera's dimensions, from the sketchup file.
The base is simple very light weight and you ll need only 3 srews in order to assembly and adapt it to your ELEV8
Althought it is a very simple and cheap accessory you can take amazing pictures and videos and you can also make some aducational activities with that base.
I'll explain in the next post....
