12V batteries voltage step down
Franny
in Propeller 1
Howdy!
What's the best way to step voltage down when using the propeller with 12V SLA or 12V (or higher) Lithium battery packs?
MC34063A- 8 pin IC for buck, boost, or inverting switching power supply design. It appears that the external components set the output voltage with a 1.25V comparison between two pins- much the same as designing a circuit for the LM317. Available for 10 cents each on ebay. (Or 50 for about $2.50)
I'm not 100% it can take a 12V input though, so that might be a deal breaker.
EDIT: Just checked- it can take up to 40V input. This thing's a freakin beast. Must be why I have a drawer full of them in my office.
R-78E5.0-0.5 from Mouser, Digikey, Element14
http://www.ebay.com/itm/LM2596-DC-Power-Supply-Step-Down-Adjustable-Buck-Converter-Switching-Regulator-/331327483066?hash=item4d24a82cba:g:z~UAAOSwPe1UIRbX
I use a similair bord with the same IC LM2596 on it, with very good result. But the input limit is 32 Volt. Not a problem for you, but think about this in an other prodject.
Greeting Abraham.
I communicate with the Propeller via Bluetooth and am currently changing over to Wifi.
Works fine. There is a blocking diode to prevent excessive discharge of the gel cell when the wall wart is connected but power is off.
The beauty here is that you can buy a 13.5VDC 1 amp wall wart and directly hook it up for a 24/7 trickle charge -- nothing fancy to create a charger. Whenever there is a power outage, the gel cell will keep the Propeller running.
Lead Acid batteries will behave nicely with a trickle charge 24/7 of about 13.5 VDC. A bit less due to a blocking diode is no big deal. The same cell will fast charge at 14.2VDC, but I never bother with fast charging.
Linear regulators of any sort will work, but create a lot of heat that may cause other problems, including just wasting more electricity.
not much at all, each adjustable with a 10-turn present. There are one's with a 7-seg LED voltmeter
built in too.
http://www.ebay.com/itm/LM2596-Buck-Step-down-Power-Converter-Module-DC-Voltmeter-4-0-40-to-1-3-37V-/262136734501?hash=item3d08912325:g:uOEAAOSwEgVWRFLz
Fuses are protective devices. The basic question is what do you desire to protect?
In higher voltages and higher power situations, we use them to protect ourselves from fire. In some cases, they are used to protect a device from extended damage if a wrong situation occurs - like a motor is stalled.
So it seems that many low-voltage, low-power situations we just omit the fuses and accept our losses.
For linear regulators the current draw from the battery is the same as the current drawn by the circuit it is powering plus the tiny bit the regulator draws.
For switching regulators it is based on the power draw of the circuit and the regulator efficiency. For example, if the circuit draws 100mA at 3.3V, the regulator is 90% efficient, and the input voltage is 12V the circuit draws 3.3/0.1 = 0.33W. At 90% efficiency the 12V supply would need to provide 0.33/0.9 = 0.367W. The current draw from the supply would be 0.367/12 = 0.031mA.
So using a 5A fuse for a 1A circuit is more than fine and besides regulators tend to limit the current anyway, except of course in the case of catastrophic failure.
On a gel cell, it is just wise to limit the battery's output to something sane in case you make a wiring error. If you are using 18 gauge copper wire or larger for primary power wiring, you can easily fry small devices while your distribution remains intact.
I have used a 3 amp fuse on a gel cell, just to deal with any really stupid wiring errors - short circuits and solder bridges in constructions. I could just as easily use 5 amps. I have blow a few too. If i were to have 10 amp fuses in a microcontroller project, there would have to be an obvious reason to need that additional 7 amps, such as driving motors from a standstill. If you get into large values, you may end up with a bag of fuses you never use.
The ideal fuse would be zero ohms, but that will never happen in the real world. The small resistance is not an issue in most situations.
My multi-meter uses a 250ma or 1/4 amp fuse which is about as low as one can go without having some problems with the fuse actually becoming an added resistance element as well. So don't bother with really tiny ones unless you have a specific device that requires them.
Such small fuses really can create more problems than they are worth. Diodes, transient suppressors, and current limiting resistors seem to take on the role of protection devices in the low voltage, low current world of ICs, or driver chips end up the scraficial element.
True, the fuse does not protect the components on the board, but having a correctly rated fuse makes it less likely that the traces and circuit board will be damaged by excessive heat or fire.
