RDBYTE instruction encoding, 78rpm error (likely) or PNut? — Parallax Forums
I am still sorting out the RDBYTE, WORD, LONG, WRBYTE etc testing. I am synthesising the instructions, and I also generate a textual list of all possible instructions / indices. The generated text is cut and pasted from PST to PNut. PNut assembles without complaint, but the binary code generated is different to the code I generate.
Here is a one test code. Note, this is not an execution error with this varient of RDBYTE, it is merely a discrepency error between my synthesis and PNut encoding.
Test number  174  rdbyte  x,  --ptra  [  1]
Error, synthesis != PNut, syn = $fb06575f  PNut says = $fb06577f
Here, snipped from the docs, is the table for encoding:
POINTER ADDRESSING MODES
INDEX = -16..+15 for simple offsets, 0..15 for ++'s, or 0..16 for --'s
SCALE = 1 for byte, 2 for word, 4 for long
S = 0 for PTRA, 1 for PTRB
U = 0 to keep PTRx same, 1 to update PTRx
P = 0 to use PTRx + INDEX*SCALE, 1 to use PTRx (post-modify)
NNNNN = INDEX
nnnnn = -INDEX
1SUPNNNNN PPTTRR eexxpprreessssiioonn
100000000 PTRA 'use PTRA
110000000 PTRB 'use PTRB
101100001 PTRA++ 'use PTRA, PTRA += SCALE
111100001 PTRB++ 'use PTRB, PTRB += SCALE
101111111 PTRA-- 'use PTRA, PTRA -= SCALE
111111111 PTRB-- 'use PTRB, PTRB -= SCALE
101000001 ++PTRA 'use PTRA + SCALE, PTRA += SCALE
111000001 ++PTRB 'use PTRB + SCALE, PTRB += SCALE
101011111 --PTRA 'use PTRA - SCALE, PTRA -= SCALE
111011111 --PTRB 'use PTRB - SCALE, PTRB -= SCALE
1000NNNNN PTRA[INDEX] 'use PTRA + INDEX*SCALE
1100NNNNN PTRB[INDEX] 'use PTRB + INDEX*SCALE
1011NNNNN PTRA++[INDEX] 'use PTRA, PTRA += INDEX*SCALE
1111NNNNN PTRB++[INDEX] 'use PTRB, PTRB += INDEX*SCALE
1011nnnnn PTRA--[INDEX] 'use PTRA, PTRA -= INDEX*SCALE
1111nnnnn PTRB--[INDEX] 'use PTRB, PTRB -= INDEX*SCALE
1010NNNNN ++PTRA[INDEX] 'use PTRA + INDEX*SCALE, PTRA += INDEX*SCALE
1110NNNNN ++PTRB[INDEX] 'use PTRB + INDEX*SCALE, PTRB += INDEX*SCALE
1010nnnnn --PTRA[INDEX] 'use PTRA - INDEX*SCALE, PTRA -= INDEX*SCALE
1110nnnnn --PTRB[INDEX] 'use PTRB - INDEX*SCALE, PTRB -= INDEX*SCALE
The difference, starting from bit 0, is at bit 5.
According to the penultimate line in the table above, bit 5 for a --ptra[n] should be 0. Which to me looks like a PNut error / problem / oversight / typo.
rdbyte x, --ptrb[ n ] exhibits the same difference in encoding and I flag it as an error.
Thank you for verifying this for / with me.
  • SeairthSeairth Posts: 2,474
    edited 2015-11-04 19:34
    %1_0101_1111 = $15F, which is what it looks like PNUT is generating.
    Edit:
    It looks like you are generating PTRA-- in your version:
    % 1_0111_1111 = $17F
    Edit edit: OOPS! Sorry. Was reading your output backwards. You are correct. I suspect that the "P" field is being inverted.
  • cgraceycgracey Posts: 14,320
    Here is what I see PNut doing:
    RDBYTE 0,--ptra[1] --> $FB04015F
    RDBYTE 0,ptra--[1] --> $FB04017F
    That looks correct.
    I don't know how you could be getting bit 5 set on a pre-dec/inc operation.
  • cgracey wrote: »
    That looks correct.
    Silly me moved a line of code to the wrong place at some point. I was OR-ing in the always 1 bit in the S register for the pointers *after* I OR-ed the S register to the instruction base.
    I have now fixed that little problem and all my synthesised binary codes match PNut's.
    So yes, the title is appropriate, "78rpm error likely"! Sorry about the panic.
  • Seairth wrote: »
    Edit:
    Thank you for your effort, I have fixed that error of *mine*.
    I have the same sorts of problems, all along the way.
  • cgracey wrote: »
    I try and laugh at myself and then move on :smile:
    Man, if you can laugh at yourself and be a friend to yourself, you can get through all kinds of things.
  • cgracey wrote: »
    If I can see a fun / funny side, I take it. Even a quiet smile is helpful.
