|< in Spin — Parallax Forums
|&lt; in Spin
ErlendErlend Posts: 612
edited 2015-11-04 17:08 in Propeller 1
I thought I had it figured out:
IF INA[PINmiso]== 1
        Framerx |= |<bitpos
-that this would put a '1' into Framerx at the bit postion given by the number held by the variable 'bitpos'?
Erlend
  • That would be my interpretation. Are you seeing something different?
  • Thanks, then I know I can trust that one is correct, so now I can concentrate on debugging elsewhere. So far I have found the classical 'forgot to clear all bits in a fresh variable' mistake. I'll nail it down.
    Erlend
  • ErlendErlend Posts: 612
    edited 2015-11-06 07:06
    Nailed down.
    This is the core method to do SPI, as part of my SPI protocol object:
    PUB Transfer(FRAMEtx) | FRAMErx, bitpos
       FRAMErx:= 0                                                       'clear all bits in input buffer
       REPEAT bitpos FROM iFirstPos TO iLastPos                          'follow the direction set by choice of MSB first or LSB first
         OUTA[PINmosi]:= (FRAMEtx & |<bitpos)>0                          'if the bit at at that postion is one, output 1
         WAITCNT((iDelay*uSec) + cnt)                                    'allow the slave time to react
         OUTA[PINclk]:= iActiveCLK                                       'leading edge of clock (whether Active is 1 or 0 is defined by SPI mode)
         IF iPhaseCLK== 0                                                'if acting on leading edge read the input now:
           IF INA[PINmiso]== 1                                           'if incoming data bit is 1
             Framerx |= |<bitpos                                         'set bit in the buffer at respective position to 1, otherwise leavi it at 0
         OUTA[PINclk]:= iIdleCLK                                         'trailing edge of clock (whether Idle is 1 or 0 is defined by SPI mode)
         IF iPhaseCLK== 1                                                'if acting on trailing edge read the input now:
             Framerx |= |<bitpos                                         'set bit in the buffer at respective position to 1, otherwise leave it at 0
       RETURN FRAMErx
    -and the bug was that
    at first was written as:
    OUTA[PINmosi]:= FRAMEtx & |<bitpos
    Now it all works fine.
    Erlend
  • That code might run faster if it was done like this:
    OUTA[PINmosi] := (FRAMEtx >> bitpos) & 1
    You can likely even drop the "& 1" from the end.
    In your version, you're ANDing FRAMEtx and (1 << bitpos) together, then testing if the result is > 0, and setting a bit in OUTA based on that. (four operations total - the shift, the AND, the test, and the set)
    In my version, FRAMEtex is shifted down so the desired bit is now at bit zero, then you're ANDing with a constant (1). The result doesn't have to be tested - you can just set the result. (three operations total - the shift, the AND, then the set). I believe the "& 1" is optional because in Spin, setting bit with a statement like "OUTA[pin] := x" only uses the low bit of x. Test it to be sure, but I think that's correct. If it is, your overall transfer rate will improve.
    Jason
    edited 2015-11-12 07:34
    JasonDorie wrote: »
    Jason
    Thanks!
    I will implement this change.
    I am curious if '1<<bitpos' is the exact same execution as '|<bitpos'? I understand the outcome is the same, but is the |< more efficient?
    Erlend
  • Erlend wrote:
    ... If it is more efficient I should use it, right?
    Even if there is a difference (which I doubt), at some point readability has to trump efficiency. I never really liked the |< operator and always use 1 << instead. It's just clearer to the non-Spin initiate what's meant by the expression.
  • I never really liked the |< operator and always use 1 << instead.
    Me too. It turns out that the Spin operator is faster than the conventional code, but the conventional code is easier for those that are not yet proficient in Spin.
  • JonnyMac wrote: »
    That's a good point. I do think readability of the code is important.
    Erlend
