String-to-float example, please (strtofloat)
in Propeller 1
I have tried many ways to get the strtofloat method to run. I run it as a method in the cfloatstr.spin library from the OBEX. Nothing works, although I know I correctly pass the starting address for an array that holds ASCII characters for -12345. The array ends with a $0 value (zero value, not ASCII 0). I always get 0 as an answer. An example of how to use the strtofloat method with a real value would be appreciated. I don't see any dependencies in the code, but perhaps I need something else running to get the strtofloat method to work. Thanks. --Jon
Here are the important components in my test program (not complete program):
OBJ
pst : "Extended_FDSerial"
StoF : "cfloatstr" 'part of clib
repeat index from 0 to 5 'Prints sign and digits as a check
pst.tx(byte[@Data_Bytes][index])
pst.tx(13)
pst.str(string("Hex address for start of string: "))
pst.hex(@Data_Bytes, 8) 'Display address of start of string
pst.tx(13) 'New line
Float_Value := StoF.strtofloat(@Data_Bytes) 'Send string-to-float array address
pst.str(string("Floating-point as hex: "))
pst.hex(Float_Value, 8) 'Print float value as 8 hex digits
pst.tx(13)
pst.str(string("...finished..."))
pst.tx(13)
DAT
Data_Bytes BYTE "-", "1", "2", "3", "4", "5", $0
OBJ
pst.tx(13)
pst.tx(13)
pst.tx(13)
DAT
Data_Addr LONG 0
In your code, you'll need:
Data_Addr := @Data_Bytes
Float_Value := StoF.strtofloat(@Data_Addr)
If you want to use the equivalent routine in FloatString 1.2 from Michael Park, you won't need the additional indirection.
