Quickstart Xbee connections
Naziba
in Accessories
Hi Everyone,
I am designing a wireless Health monitor. I have designed the sensor system on the propeller quick start board using a DS1620 Thermostat and an Memsic 2125 dual axis accelerometer. I have the results on the PST terminal perfectly.
I want to transmit this data wirelessly by Xbee S1 pro series to the base node of another USB adapter. Could anyone suggest me any code to run with the Quickstart .
Naziba
Naziba
If you want to get fancy, you can configure the XBee from the QuickStart Board using PST to send the commands. The XBee documentation describes what you have to send and how to get the XBee into command mode.
