RGB LEDs Strike Again! — Parallax Forums
cgraceycgracey Posts: 14,323
edited 2015-10-30 22:05 in Propeller 2
Yesterday, the first Prop123-A9 board came off the assembly line and it didn't work. Power supplies seemed dead and would drag the power input to just a few volts. I spent lots of time trying to figure out what the problem was and if something had changed. I couldn't find anything.
Daniel called, who designed the board, to find out how it was going. After about a half hour on the phone, checking everything, he asked how those RGB LEDs were oriented. Indeed, the pin1 indicator was where pin1 should be on the PCB. He remembered that there was something funny in the past about those WS2812B parts having the polarity indicator OPPOSITE of pin1, on pin3. Sure enough, I clipped them off and the board powered up!
We almost decided to get rid of those RGB LEDs on the last PCB rev, but we decided to keep them, barely. We should have gotten rid of them, as they are not only tricky, but can easily die during reflow.
Now, I'm thoroughly testing the design to make sure it does everything, like PLLs and what not. We got rid of the PCI-Express edge connector and just put a 256Mb SDRAM on there, all set to 3.3V. That is what we are going to need for Prop2, since the I/O's only work at 3.3V.
Hopefully, in a few hours, we'll know that everything's all right and on Monday morning, they can crank out 30 of these things. There has been a big rush to get this thing debugged, because it's all set up on the pick-and-place now, and it's a bear to take down and set up again.
Try to guess how many parts are on this PCB! My dad guessed 40, which is what I might have thought, not knowing much about it. Make a guess.
  • cgracey wrote: »
    397
    The chance of an error in any process is directly proportional to the cost of that process.
  • jmgjmg Posts: 15,200
    cgracey wrote: »
    Make a guess.
    601
    Man, you guys are pessimists, but realists, as well.
    There are 416 parts on that board! Most are just bypass caps.
  • RaymanRayman Posts: 16,460
    edited 2015-10-30 22:30
    I'd guess same as A7 version plus 2
    BTW: Even regular SMT LEDs are a pain to orient. I have red and green ones from the same manufacture and the polarity marks are on opposite sides...
    Rayman wrote: »
    It has probably ~30 more parts, due to pi filters on the PLL supply pins, plus the SDRAM and its 7 bypass caps.
  • Does this mean that the boards will be ready for us in the next week or so? (paging Ken)
    Roy Eltham wrote: »
    Once they're built and tested, they can ship. They could be done on Monday or Tuesday.
  • So does this mean that you've decided to leave the RGB LEDs off of the final boards?
  • cgracey wrote: »
    Chip, killing RGB LEDs during reflow has one common denominator: excessive peak temperature. I don't recall what you guys have for profile validation, but that would be the best place to start.
  • Awesome looking forward to having a play with these boards :D
    David Betz wrote: »
    No. We just need to put them on the right way.
    edited 2015-10-31 16:18
    cgracey wrote: »
    These RGB LEDS have been very problematic for us. I think there's a quality issue with them, aside from our reflow process.
    Unfortunately, high temperatures are needed for the new "environmentally-safe" lead-free solder chemistries.
    If the parts sit around for too long, absorbing moisture, they can pop during reflow.
    The metal contact surfaces also oxidize and lose their wetting ability, becoming unsolderable.
    The old tin/lead system was 10x more reliable. Never did soldered parts just fall off boards, before.
    This new system came about by EU mandate and, suddenly, Heller reflow ovens were all over the world. Even Parallax needed one to reflow the new solder, so that we could continue to sell products.
    This whole thing seems, to me, to be about staid industry using government to force existing players into buying new equipment.
    In farming, "Nothing runs like a Deere", until they lobby the government to pass new diesel emission requirements, forcing their existing customers to buy a new, very expensive, tractor that they don't need or want. Oh, and that they can't repair, themselves, anymore.
    These things are all scams to redirect the profits of the little guys back into the hands of the big guys. This is why environmentalism is so divisive. Those in small business see that it's relentlessly exploited to undermine them, and favor those cozy with government.
  • rjo__rjo__ Posts: 2,114
    When I was a kid, the very best Christmas present was a kit to allow eight year olds to make tin soldiers... out of lead. .
    We drank "pure water" ... "comes all of the way from Canada"... which turned out to have levels of radium so high that the good State of Illinois had to rewrite the law to allow us to continue to drink it... and not a word of it in the local paper.
    So, anyone believing that environmentalism is even remotely related to a concern for the "little" guy needs to get his history straight.
    I am tempted to buy a VW and restart my "global warming thread." Right after I get done playing with my P2:)
    But more to the topic... just put them in a little bag and let us worry about it...
    Be American about it. Charge extra for the bag. They are non-disposable and you can always give a refund if someone wants to send it back.
    Conductive paste seems like a good option here. Who knows maybe we can start a trend:)
    edited 2015-11-04 03:59
    "Global warming"?
    Surely, you mean "global taxing". There won't be any denying that.
    All right. I'll stop. I don't want to induce nausea in any Prop 2 testers out there.
    edited 2015-11-04 05:47
    idk, we are a pretty happy group right now.
  • Dear Alexander,
    Thank you for your interest in Master Bond.
    I am recommending EP21TDCS for your application which involves bonding copper trace to tin. EP21TDCS is a two part silver filled epoxy that has high bond strength and very high electrical and thermal conductivity. It has a convenient 1:1 mix ratio, and an estimated 60-90 working life. It can be cured at room temperature or with heat. To optimize its properties, I recommend curing this overnight at room temperature and following that with a post cure for 3-5 hours at 150 F.
    If possible, I recommend roughening the tin to an RMS of 150-250 micro-inches to optimize adhesion.
    Please review the attached data sheet and feel free to contact me if you need any further technical assistance.
    Please contact our customer service department at 201 343 8983 to obtain information on pricing and to order this adhesive.
    Once again, we thank you for your interest and look forward to servicing your company's needs.
    Best Regards,
    Michael Wollman
    Technical Support
    mwollman@masterbond.com
    I got this reply when I asked MasterBond about a suitable substitute for solder in surface mount applications. Might be worth looking at.
    Sandy
  • evanhevanh Posts: 17,313
    Hmm, an outright glue. That would be a mindset change as well. What does 60-90 working life mean?
    150-250 micro-inch is roughly 6-10 um.
    evanh wrote: »
    I think that would be the number of minutes before the glue solidifies.
  • Are you guys baking the LED's for 24 hours prior to reflow? Moisture is the killer, this chip expands and causes parts to separate with any amount of moisture.
  • I don't know why, but clear plastic parts seem particularly prone to moisture incursion along the leadframe. My assembler has to bake both the TSL1401 and TCS3200 chips to drive the moisture out before placing and reflowing them. Otherwise, I'd end up in the same situation as Parallax with their RGB LEDs.
  • With unbaked WS2812B LED's, you hear an audible pop in the chip when you use place one with hot air. However, the pads are able to be soldered with a pencil if you get in and out quickly without damage.
  • There are several variables here that make this issue difficult, but definitely not impossible, to resolve:
    1) Quality of the part itself
    2) Storage condition of the raw part from the supplier (sealed moisture barrier bag? probably not)
    3) Raw parts baked and sealed for storage upon receipt?
    4) If not 3, parts baked prior to use per MSL specifications?
    5) Lack of proper reflow characteristics for the component. Their recommendations for lead and lead free profiles contradict each other in terms of what the part can handle.
    6) Thermal challenges imposed by the PCB design. In other words, profile requirements for the Altera 484 ball FBGA are different than the LEDs due to thermal mass differences of the PCB where these parts are located.
    7) Reflow oven capabilities/limitations. If I recall correctly, Parallax has a 7 zone oven, which makes it more difficult to create a profile that will meet both the Altera chip's needs and those of the LEDs. My first suspicion would be that the LEDs are being stressed a little too much during reflow because the reflow profile is geared towards success of the FBGA
    Other than the quality issue of the raw part itself, none of these variables are impossible to overcome.
    Chip, as I always tell Ken, I would be happy to swing by and assist with any process improvements if desired. I could bring my SlimKIC 2000 wireless reflow profiler to validate the PWI of your oven for this board.
