CZ flag standardized order — Parallax Forums
Chip
The condition definitions show thr following aliases
%0001	if_nc_and_nz	if_nz_and_nc	if_a		if_00
%0100	if_c_and_nz	if_nz_and_c			if_01
%0010	if_nc_and_z	if_z_and_nc			if_10
%1000	if_c_and_z	if_z_and_c			if_11
Using the aliases of IF_00,IF_01,IF_10 and IF_11 assuming the same order as the SETCZ instruction the result is transposed.
		setcz	#%01 wc,wz	'force task1
	if_11	jmp	#task3
	if_10	jmp	#task2		'jumps to task2
	if_01	jmp	#task1
	if_00	jmp	#task0
Just a little "tweak" to Pnut :)
    Ah, I will fix that. Thanks.
  • Can you also add aliases "if_xxxx", where each x is either 0 or 1 and corresponds directly to each of the four CCCC bits?
    e.g. "if_0110" is the same as "if_z_ne_c", and "if_1000" is the same as "if_z_and_c"
    The problem with this is that it will probably be easy to get the middle two bits mixed up.
    edited 2015-10-23 13:07
    Those should already be in there.
    The CCCC bit interpretations are the same as they were on the P1.
