Blue Scribbler software? — Parallax Forums
I have some old scribbler robots. Should the scribbler 2 robot soft ware work with the old blue robots? Im getting an error message that says that there is no communication. Any help would be great...
    edited 2015-10-19 14:41
    No. The S2 software is for the Propeller chip, and the S1 software is for the BS2.
    Two different Microcontrollers in the two BOTs.
    Do you need the old software?
  • I do have a disk with the old software. Will it run on Windows 7 ?
    edited 2015-10-19 15:31
    Yes. I have it installed on WIN 7 and WIN8.1
    Just make sure you install The USB(FTDI) drivers.
  • The Scribbler 1 (blue) software is also available here:
    https://parallax.com/downloads/scribbler-program-maker-gui
  • Thanks Jen! Was not easy to find for me. But then I can become distracted. :)
    Like the new Icon.
    Jen: I looked briefly but did not see the blue Scribbler factory program. Is it still available? It was not a BASIC program download, but an executable file IIRC.
    edited 2015-10-22 17:06
    Publison wrote: »
    Warning!! It will not install on 64-Bit machines.
  • erco wrote: »
    I think it was a BS2 file. See attached.
    Thanks Jim, I figured a BS2 file was around. But IIRC, on scribblerrobot.com there was a button you could click to restore a connected Scribbler and you'd never see any code. Magic.
  • You can restore a Scribbler 1 via the original Scribbler Program Maker GUI. With the Scribbler connected, click the icon that shows the robot with a halo over it. That re-installs the factory default software.
